| REW Forum waterfall graph and printingDiscuss waterfall graph and printing in the Equalization | Calibration forum; waterfall graph and printing I have two questions. One I asked before and I couldn't solve, the other is new.
The easy one first. ... |
Views: 331 - Replies: 4
| waterfall graph and printing I have two questions. One I asked before and I couldn't solve, the other is new. The easy one first. Is there a way to print the graphs and plots along with the info? The other is my waterfall graphs are flat for the first 100ms then start to roll off. I notice on other peoples posts thier graphs start to roll off right from the second line. On mine its flat for seven lines before showing any rolling off. This makes my waterfall and spectral dacay graphs hard to read. What settings do I have wrong? | ||||
| | #2 | ||||
| Re: waterfall graph and printing Hard to say without seeing the graph... Regards, Wayne | ||||
| | #3 | ||||
| Re: waterfall graph and printing I hope this works, As you can see the first bunch of line as all at the same level | ||||
| | #4 | ||||
| Re: waterfall graph and printing Open the Settings, go to the Analysis tab and under the Impulse Response Window Defaults change the "Spectral Decay Left" window type to Hann (it is probably Tukey 0.25). To capture a screen shot of a graph click the floppy icon in the bottom left corner of the graph area or select "Save Graph as JPEG" from the graph menu. The graph images do not include the legend at the moment but (optionally) will in the next release. | ||||
| | #5 | ||||
| Re: waterfall graph and printing John, That did it. I feel so much better . Thanks for the help. | ||||
