Hello Everyone,
First time poster here and need some help on implementing a house cure or a hard knee house curve. I've read
Wayne's tutorial on both many times but I'm having some trouble applying it in real life and having it sounding good. The speakers are a pair of DIY JBL M2's and the amplifier is a Crown DCI 4300N using the preset DSP from Crown for these speakers. I started out by taking measurements from three listening positions. At each position three measurements were taken with each left and right speaker. A total of 18 Reference Points were taken. Please see Picture 1 for the average.
From here I used the recommended window Level of 130/20 from Wayne's House Curve Tutorial and raised the target
level to 77db. I received what's in Picture 2 with two parametric values of 56.20Hz and 32.30Hz. Should I be doing more smooth the dip at 240 and the rise at 600Hz? I tried some values for the 240 pint of interest and it sounded muffled and was wondering I was doing something wrong. I also read that Wayne's curve was around 16db from the low frequency to the high, but haven't even started to tackle this yet. The speaker crossover point is around 750Hz.
Picture 3 is the parameters for the calculated EQ. I have very little EQ experience and would really appreciate any help.
Thank you,
Scott
Thank you,
Scott
