REW Forum
REW is seeing low level from my SPLmeter/ADcard
Discuss REW is seeing low level from my SPLmeter/ADcard in the Equalization | Calibration forum; REW is seeing low level from my SPLmeter/ADcard Hi everyone, I'm new here and I'm trying to measure my control-room response. I just purchased the digital RadioShack SPL ...
Views: 281 - Replies: 3
Old 01-10-09, 01:28 PM   #1
New Member
Alias: magibatalla
Loc: Sant Sadurní d'Anoia
User: #30897
Since: Dec 2008
  magibatalla is offline
I just purchased the digital RadioShack SPL meter. My audio interface is a Prism Sound Orpheus (8in-8out). I'm running a MacPro Dual 2,66 with OSX 10.4.11 (Tiger). My monitors are a pair of Genelec 8030.
My room is about 9,5 x 8,5 x 7,8 (WDH) feet. Front wall is covered with a 4x6 broadband absorber and two 3x6 corner bass traps. Auralex LENRD bass traps cover 50% of the surface where walls meet ceiling. A thick carpet on the floor.
Before installing REW, I did a quick calibration of my monitors (with their onboard level control) so the SPL meter (placed on my mix position) read 85dB when the speakers were playing a -0dB white noise signal from my DAW. Each speaker on its own gave a 79dB reading.
Then I turned REW on, read the HELP file and tried to do my first measurement. I loaded the calibration file for my RadioShack digital meter. When REW checked the incoming signal from the meter, it said level wasn't high enough to do a proper measurement.
My meter is connected to the 1st Orpheus line input with an RCA to TRS cable. Orpheus' control panel reads about -12dB incoming signal in that channel, but REW doesn't seem to hear that level.
Any suggestion? Thanx!
Old 01-10-09, 04:19 PM   #2
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Re: REW is seeing low level from my SPLmeter/ADcard
Welcome to the Forum!
This might be your problem:
Try an RCA to TS cable.
Old 01-10-09, 06:22 PM   #3
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
You also need to set the inputs you are using as the defaults in the Mac's audio-midi preferences before starting REW. If you have problems getting REW to see the signals from the Prism you could also use the built-in audio input on the MacPro.
Old 01-11-09, 03:52 AM   #4
New Member
Alias: magibatalla
User: #30897
Since: Dec 2008
Thanks for your input, Wayne. I'm actually using a TS cable, I wrote the wrong name. My fault.
JohnM wrote: View Post
Thanks, John, I think it rather has to do with this. I messed with the Mac's preferences and REW's audio setup for a while but couldn't find out what was not letting it work. I'll switch to the built-in audio input.
level, splmeter/adcard
