REW Forum
What's my EQ'd "ideal" target
Discuss What's my EQ'd "ideal" target in the Equalization | Calibration forum; What's my EQ'd "ideal" target Over the weekend, I inserted three EQ's into my system to correct the levels on my left/center/right. I worked towards ...
Views: 447 - Replies: 2
Old 01-12-09, 09:59 AM   #1
Alias: ghstudio
User: #10487
Since: Jul 2007
  ghstudio is offline
Over the weekend, I inserted three EQ's into my system to correct the levels on my left/center/right. I worked towards a flat response curve, taming peaks and boosting valleys. The result is much improved balance...much smoother blend of sound. I also tuned my sub (no eq yet) and got the crossover settings right although I still have to play with the phase (I'm not sure I hear a difference).
While the sound is certainly more balanced and flatter, I know that in the real world, one does not always strive for flat frequency response. I know in my lexicon processor, I can boost Voice by 3-6db and make some other adjustments. While I could play and tune to ear, I'm not sure that my ear is anywhere close to the right ear. Last night watching some HDTV, the system sounded a bit muffled....and that might be due to over correction.
Does anyone have a good EQ curve for home theater that they would recommend....or is there some place on the web that shows how one might set an EQ for different types of music/voice/Home Theater?
Old 01-12-09, 10:13 AM   #2
Alias: brucek
User: #6
  brucek is online now
Re: What's my EQ'd "ideal" target
You will likely need to set a house curve with REW when you get a BFD.
Old 01-12-09, 06:18 PM   #3
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
ghstudio wrote: View Post
If you’re new to full-range equalization, you might want to check this thread for lots of tips on how to properly equalize the main channels, so as to reap the benefits and avoid the pitfalls.
Could have been the particular program you were watching...
There are a couple of articles on house curves at the link in my signature.
"ideal", eq'd, target, what's
