| REW Forum trying my new cm140Discuss trying my new cm140 in the Equalization | Calibration forum; trying my new cm140 Here is a graph I made with my new cm-140. I used a test tone CD going from 15 to ... |
Views: 287 - Replies: 9
| trying my new cm140 Here is a graph I made with my new cm-140. I used a test tone CD going from 15 to 120 Hz. ![]() Just curious how this looks and if you think I will need to get a BFD or not? Are the bumps in the 30-40 Hz range and around 80-85 Hz going to make it boomy? I will try REW once I get my cables/connectors in the mail on Wednesday. I just had to play with my new toy! | ||||
| | #2 | |||||
| Re: trying my new cm140 Quote:
Regards, Wayne | |||||
| | #3 | |||||
Go to the download page and get the CM-140 calibration file and use the values to correct your readings. (open the cal file with notepad to reveal the text values). Then take a look at the graphs in this manual measurement excel file for a Radio Shack meter. Use the same values for your graph scaling. The scaling is in octaves (how we hear) and it will be a better representation of how you hear your subwoofer. brucek | |||||
| | #4 | ||||
| Re: trying my new cm140 Thanks for the links. Not sure if this is correct, but here is my last effort before I try REW sometime tomorrow ... disregard below 16 hz and above 120 hz . First graph must have been way off. ![]() | ||||
| | #5 | ||||
| Re: trying my new cm140 Yeah, you have a peak at 40Hz for sure, but wait until you get REW running before doing anything drastic..... ![]() Read and become familiar with the REW HELP files and the REW Cabling and Connections Basics. Also note the REW information Index and the Download Page. brucek | ||||
| | #7 | ||||
| Re: trying my new cm140 Use C weighting, and do check the C weighted SPL meter box. | ||||
| | #8 | ||||
| Re: trying my new cm140 Ok, got REW going finally. Here is one of my measurements ![]() No matter where I move the meter, there is always the peak at 40 Hz, and there is a null at around 75 that gets worse the farther I move away from the left side of the couch. The right side of the couch will drop down to 46 dB around 75 Hz even if I move the crossover to 150. I will try and move the sub tomorrow (only 2 other places it can go). Btw, should there be any smoothing applied when posting? I didn't with these. | ||||
| | #10 | |||||
Post graphs with a horizontal scale of 15Hz-200Hz. brucek | |||||
