REW ForumDiscuss back for more - full range this time in the Equalization | Calibration forum; back for more - full range this time Basically I agree with weverb. The ~85 Hz hump is probably audible and should be tamed. It's hard to tell ... |
Views: 1876 - Replies: 68
| | #21 | ||||
| Re: back for more - full range this time Basically I agree with weverb. The ~85 Hz hump is probably audible and should be tamed. It's hard to tell since the graph stops at 5 kHz, but overall the mains seen to exhibit a gradual rise from ~200-5kHz. Most likely this is going to make the mains sound thin or shrill. The overall trend for the mains should be flat, or perhaps a gradual decline, in order to sound natural. You might want to take a look at Part 2 of my house curve article (there's a link to it in my signature). Fortunately, this would be easily to fix with the receiver's basic tone controls. Regards, Wayne | ||||
| | #22 | ||||
| Re: back for more - full range this time Yeah, It does look like I need to tame that 80-100hz region. Since the crossover is at 80hz, that region falls on my main speakers. Maybe I should move the crossover up to 100hz and re-measure the FR. If it still there then I can tame that using my BFD (hooked with the sub). A little more details info about my setup. I'm running 5.1 system. * sub is huge port (LLT) * 3 diy front speakers and two small monitor as surrounds. * receiver = pioneer 1014 (can't remember the exact model) * all my speakers are plugged in the emotive amp = LPA 7 channels amp * room are about 3000 cu feet = living room + kitchen * current parametric eq = BFD1124 * using RS analog SPL meter * mostly watch movies more than music (most of the time I like watching concerts dvd) Hope this extra info can help you guys understand more about system. I'll see if I have some time to measure it again with different xover. I'll post some more graph soon ![]() Thanks for the help guys. Al, | ||||
| | #23 | |||||
| Re: back for more - full range this time Quote:
| | #24 | ||||
| Re: back for more - full range this time I got some measurements done tonight. I've noticed something is off with the xover on my reciever. See graphs below: Subwoofer graph at crossover 100hz with no eq. From what I see, I think the xover is actually at 68hz and not 100hz (dip on that region). The peak is in 80-100hz region. I did try to tame down the subwoofer on that region 80-100hz. But my filter take no effect so I think the xover isn't really at 100hz but lower. Also, I tried to add some gain on 65hz region. Again nothing changed on that filter. ![]() Subwoofer graph xover at 150hz. (Blue = no eq, Red = eq). Noticed the 80-100hz has dropped down a bit. Noticed the 65hz filter is improved this time. ![]() Subwoofer graph 150hz xover with eq and smoothing. It looks like I got myself a house curve ![]() ![]() Full Range xover 150hz with eqs through receiver. I manually set eq at 125hz, 300hz, 4k, 13k. Light green orange = final eq; dark purple = no eq through receiver; bright purple = eq through receiver. ![]() It looks like I got some positive progress through eqing from the receiver Fortunately, I can't localize the bass even though my crossover is at 150hz (probably off on receiver). I only have time to listen for about 15 mins though. I need to put some time listening to my system to see if the crossover at 150hz is suitable. Other than that the graph looks better ![]() Al, Last edited by wackii; 01-21-09 at 01:51 AM.. | ||||
| | #25 | ||||
| Re: back for more - full range this time That looks so much like the response I had from last month besides bellow 25Hz I am amazed. I moved the mains further from the seats and closer to the side walls, then checked phase, adjusted speaker distances.. The 80Hz crossover is a bit like having stereo subs and can be a bit distracting. I thought 100Hz was alright but 150Hz was really eating into my subs headroom. Are you aiming your mic directly up? | ||||
| | #26 | |||||
Thanks for your inputs. Al, | |||||
| | #27 | ||||
| Re: back for more - full range this time brucek told me something like this for testing xo: http://www.hometheatershack.com/forums/rew-forum/12622-rew-noob-5.html#post115700 Don't know if it will help. ![]() | ||||
| | #28 | |||||
The White Noise should track the crossover slope, or the 12dB Octave one if using that, on the filters tab window. | |||||
| | #29 | |||||
Thanks for the link. I will give that a test. Al, | |||||
| | #30 | |||||
Sorry, I'm totally lost. Al, | |||||
