REW Forum
back for more - full range this time
Discuss back for more - full range this time in the Equalization | Calibration forum; back for more - full range this time Hi all, I want to attempt to calibrate my main speakers this time around. I had successfully calibrated my sub ...
Views: 1490 - Replies: 68
Old 01-15-09, 04:18 AM   #1
Alias: Wackii
Loc: I ain't tellin ya!
User: #1530
  wackii is offline
Hi all,
I want to attempt to calibrate my main speakers this time around. I had successfully calibrated my sub (flat to 13hz) about 2.5 years ago. I've just did some reading these last few days and decided to use REW to calibrate my main speakers this time. I understand that I need some thing better than the RS sound meter for full range. The ECM8000 mic seems to be the best candidate for me since I've already have a mixer, Alesis MultiMix8. I have few questions though.
1. The Alesis Mixer have 3 eq knobs (hi, mid, lo). What level should I set them at? Should I turn them all down, set it in the middle, or at max? It also has 2 effects knobs (pre, post) where should I set them at? Should I turn off all the eq and/or effects on the mixer?
2. I do have a different mic that I use to sing Karaoke. Can I use that mic for this job? The mic is Sennheiser E835. My guess is no since I need the calibration file? Just want to throw it out here for the pros.
3. Can the BFD DSP 1124P use for calibrating the main speakers? Currently I'm using it to eq my sub. I might need one more for the mains unless you guys recommend something else (less than $100).
4. Do I need to measure one speaker at a time or I need to run both speakers on?
5. Hook-up wise, do I need to run the cable directly to each speaker line-in during the measurements? Or I can just plug it to the AUX line-in?
Sorry for so many questions. I just want to clear things up a bit.
Thanks.
Al,
Old 01-15-09, 07:40 AM   #2
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Re: back for more - full range this time
Hi Al,
Set the EQ knobs straight up. You don’t want them influencing speaker response. Better yet, use the Aux A send for your testing. It will totally bypass the EQ section. Don’t forget to run your calibration routine between the line input and the Aux A output. And make sure your receiver's tone controls are bypassed, too.
Re the Aux outputs: In a recording setting,they could be used as a separate mix for a recorder, while the main mix would be for the monitoring system. In a live situation, the Aux sends are typically used for stage monitor mixes. For REW they generally have no use, but as I mentioned, since Aux A does bypass the EQ section, it might be better suited for the job.
A calibration file is needed for any mic used.
Most feel the BFD isn’t clean or quiet enough for full-range use, but feel free to experiment for yourself. The consumer-level setting (switches on the back) reduce background noise, so that’s probably the setting you’ll want to use. There’s no such thing as a good equalizer for under $100. Maybe a used vintage pro audio model, but nothing new.
If you don’t get the mic situated at a perfect equidistance between the two speakers, you can get comb filtering, due to the inexact time alignment. So, it’s best to test one at a time. If you have a dedicated room with symmetrical “shoebox” dimensions, then it’s sufficient to measure only one of the speakers. Any EQ needed will be relevant to the second speaker. If your room is asymmetrical (like maybe a family room with openings all over the place), then take separate readings of the two speakers. You’ll get the best results with the mic pointed at the speaker, less than 45˚off axis. If you point the mic too far off axis, the graphs will show reduced high frequency response.
You might want to take a look at this thread about full-range equalization. It has tips on how to measure, interpret the results, and how to tell a good equalizer from a questionable one.
http://www.hometheatershack.com/foru...ase-chime.html
Which cable? Not sure what you mean “speaker line in.” Just connect things the same way you did for your first REW calibrations.
Old 01-15-09, 04:13 PM   #3
Alias: Wackii
User: #1530
  wackii is offline
Thanks for the help. What is a good equalizer for full range speakers? Something that won't burn my pocket. If possible, can you list me a few decent equalizer?
Thanks.
Al,
Old 01-15-09, 08:08 PM   #4
Alias: weverb
Loc: Florida
User: #24376
Since: Aug 2008
  weverb is offline
Yamaha YDP2006
http://www.yamaha.com/yamahavgn/CDA/...%253DN,00.html
Rane PE17
http://www.rane.com/pe17.html
Symetrix 551E
http://support.symetrixaudio.com/s.n....KB/KB.4374/.f
Old 01-16-09, 03:24 AM   #5
Alias: Wackii
User: #1530
  wackii is offline
Thanks weverb. I've just double checked. All these are discontinued. Most stores don't have them anymore. I'll keep an eye out for used products. Thanks.
Al,
Old 01-16-09, 08:48 AM   #6
Alias: weverb
Loc: Florida
User: #24376
Since: Aug 2008
  weverb is offline
Here is a good source for used YDP's:
http://www.saviusa.com/equipment_sales.html
Ask for Shawn and tell him Bryan sent you. He will send pictures and do testing before sending you a unit. I purchased my last two from him.
Ebay has two Rane PE 17's listed right now.
There is also an Ashley eq for sale. Wayne has recommended these in the past. I have not tried one on my highs though. It is a one channel, which could work for a center channel. I would look for the 2 channel version.
http://cgi.ebay.com/ASHLY-PQ-16-Six-...3A1|240%3A1318
There is also the XTA DP202. No one has tried it, but it looks to be a good unit. There is a single channel version also (DP100).
There is also the Sabine ADF4000. It can be controlled by a laptop or manual. I tried a different Sabine eq on my rear channel and was getting some noise. When I tried it on my subs, it was quiet. The ADF4000 may be different though.
Wayne is the best source though for eq recommendations. Let's see what else he recommends.
Old 01-17-09, 03:34 PM   #7
Alias: Wackii
User: #1530
  wackii is offline
Great... Thank you Bryant.
One more question, what is the different between the Rane PE-15 compared with the Rane PE-17... From what i've read, they are both 5 bands Parametric EQ...
Thanks.
Al,
weverb wrote: View Post
Old 01-17-09, 04:26 PM   #8
Alias: weverb
Loc: Florida
User: #24376
Since: Aug 2008
  weverb is offline
wackii wrote: View Post
Stay away from the PE15. It has been proven to introduce a lot of noise into a system. It is not good for highs.
Old 01-17-09, 05:18 PM   #9
Alias: Wackii
User: #1530
  wackii is offline
Thanks for the heads up... I was able to find 2 on craigslist for cheap... Anyway, I will try to measure my speakers first then will see if I need some eq... my receiver got some eq built in as well...
Thanks.
Al,
Old 01-17-09, 07:28 PM   #10
Alias: weverb
Loc: Florida
User: #24376
Since: Aug 2008
  weverb is offline
Be careful. This could happen to you! Thanks to Wayne's bad influence.
Old 01-18-09, 10:16 AM   #11
Alias: Wayne
Loc: Katy, Texas
User: #8
Wow, first time I ever saw tennis balls as part of a home theater set-up.
Old 01-18-09, 11:35 AM   #12
Alias: weverb
Loc: Florida
User: #24376
Since: Aug 2008
  weverb is offline
They are good for additional 3dB!
Actually they help keep the two separated so they do not get too hot. I am still researching different locations for all of them. Obviously it has to be WAF approved.
Old 01-19-09, 02:22 AM   #13
Alias: Wackii
User: #1530
  wackii is offline
I sat down today and got some measurements done. After more than 2 years, my FR has changed... It wasn't as smooth as before but decent I think. I have added a few furnitures and moved the sub in a lil to make room... There wasn't a major thing I needed to do on BFD. I added 4 filters and I think it's good enough... Unless, you guys see it differently... Here are the graphs:
Sound card calibration pix.
Subwoofer xover 80hz graph with 4 filters (20hz -3db, 27hz -4db, 41hz -4db, 63hz +6db).
Same thing in waterfall. It looks like bottom heavy. Should I minus the gain on BFD a lil more?
Full Range up to 5k hz since my RS analog meter isn't accurate beyond that.
Waterfall.
All graphs are without smoothing... Any pointers? Please let me know.
Thanks.
Al,
Old 01-19-09, 02:59 AM   #14
Alias: Wackii
User: #1530
  wackii is offline
Are those the three YDP2006? You're probably in audio heaven with those toys. The sound must be well balanced I want to hear a before and after EQ. I've been looking for stores that can demonstrate a before and after EQ but can find none. Most stores are just into selling you big name brand items and never/seldom go into details like eq stuffs...
Oh by the way, great invention on those tenis balls. They must be rattle-free due to the ball absorption
Old 01-19-09, 08:19 AM   #15
Alias: weverb
Loc: Florida
User: #24376
Since: Aug 2008
  weverb is offline
Yup, those are the YDP's.
I must say that my set-up has never sounded so good. I can tell the biggest difference when listening to music. On movies, the center blends much better now. I am still trying to deal with the cabinet placement. I may move it in the future though.
The tennis balls have helped mostly with heat. The YDP's did not like resting on one another. I think the biggest contributor to the heat problem is having them stuffed in the cabinet. They cannot breathe. I have to leave the door open a couple inches while listening. The third one has not gotten hot sitting in its test/current location.
As for your graphs, you look to be a little "bloated" in the 80-100Hz range. Can we see the full range plot (fourth one down) with 1/3 octave smoothing applied?
Old 01-19-09, 08:44 AM   #16
Alias: Bill
Loc: Southeast MI
User: #28669
Since: Nov 2008
  t6902wf is offline
I read briefly about the YDP2006. Why do you need three?
Sub, center and mains?
Old 01-19-09, 08:50 AM   #17
Alias: weverb
Loc: Florida
User: #24376
Since: Aug 2008
  weverb is offline
t6902wf wrote: View Post
One YDP for left and right rear channels.
One YDP for center and subs.
One YDP for left and right mains.
Total of three.
The fourth eq (Symetrix 551E) is for <20Hz. tuning.
Old 01-19-09, 11:32 AM   #18
Alias: Wayne
Loc: Katy, Texas
User: #8
Hard to judge the effectiveness of your EQing without a baseline graph.
No, it’s fine. It’s common to have long decay times at the lowest frequencies. EQing that to make the waterfall look good will wipe out your excellent extension.
Full range graphs typically need to be smoothed. Try 1/3-octave smoothing.
Waterfall.
Typically no good reason to waterfall above the bass frequencies or perhaps lower midrange.
Old 01-19-09, 02:49 PM   #19
Alias: Wackii
User: #1530
  wackii is offline
Here is the graph with 1/3 smoothing.
There is the graph before eq. I forgot to save the measurement data. Only got the image saved.
Thanks.
Al,
Old 01-19-09, 08:24 PM   #20
Alias: weverb
Loc: Florida
User: #24376
Since: Aug 2008
  weverb is offline
I will let Wayne give you his official thoughts. I still think the 75-100Hz area looks too high compared to the rest. The one thing that I see that may help with the highs is the 375-500Hz dip. I am not sure if it is wide and deep enough though. There also may be an over sag between 200-1,000Hz. compared to the lows and the 1k-5K area. But let's wait and see what Wayne says.
Old 01-20-09, 12:20 PM   #21
Alias: Wayne
Loc: Katy, Texas
User: #8
Basically I agree with weverb. The ~85 Hz hump is probably audible and should be tamed.
It's hard to tell since the graph stops at 5 kHz, but overall the mains seen to exhibit a gradual rise from ~200-5kHz. Most likely this is going to make the mains sound thin or shrill. The overall trend for the mains should be flat, or perhaps a gradual decline, in order to sound natural. You might want to take a look at Part 2 of my house curve article (there's a link to it in my signature). Fortunately, this would be easily to fix with the receiver's basic tone controls.
Old 01-20-09, 03:35 PM   #22
Alias: Wackii
User: #1530
  wackii is offline
Yeah, It does look like I need to tame that 80-100hz region. Since the crossover is at 80hz, that region falls on my main speakers. Maybe I should move the crossover up to 100hz and re-measure the FR. If it still there then I can tame that using my BFD (hooked with the sub). A little more details info about my setup.
I'm running 5.1 system.
* sub is huge port (LLT)
* 3 diy front speakers and two small monitor as surrounds.
* receiver = pioneer 1014 (can't remember the exact model)
* all my speakers are plugged in the emotive amp = LPA 7 channels amp
* room are about 3000 cu feet = living room + kitchen
* current parametric eq = BFD1124
* using RS analog SPL meter
* mostly watch movies more than music (most of the time I like watching concerts dvd)
Hope this extra info can help you guys understand more about system. I'll see if I have some time to measure it again with different xover. I'll post some more graph soon
Thanks for the help guys.
Al,
Old 01-20-09, 05:35 PM   #23
Alias: Steven
thewire's Avatar
Loc: Midwest
User: #9828
Since: Jun 2007
  thewire is offline
Al,
I have the same problem and near the same size room. Using the BFD and setting the crossover higher should help a great deal.
Old 01-21-09, 02:46 AM   #24
Alias: Wackii
User: #1530
  wackii is offline
I got some measurements done tonight. I've noticed something is off with the xover on my reciever. See graphs below:
Subwoofer graph at crossover 100hz with no eq. From what I see, I think the xover is actually at 68hz and not 100hz (dip on that region). The peak is in 80-100hz region. I did try to tame down the subwoofer on that region 80-100hz. But my filter take no effect so I think the xover isn't really at 100hz but lower. Also, I tried to add some gain on 65hz region. Again nothing changed on that filter.
Subwoofer graph xover at 150hz. (Blue = no eq, Red = eq). Noticed the 80-100hz has dropped down a bit. Noticed the 65hz filter is improved this time.
Subwoofer graph 150hz xover with eq and smoothing. It looks like I got myself a house curve
Full Range xover 150hz with eqs through receiver. I manually set eq at 125hz, 300hz, 4k, 13k.
Light green orange = final eq; dark purple = no eq through receiver; bright purple = eq through receiver.
It looks like I got some positive progress through eqing from the receiver Fortunately, I can't localize the bass even though my crossover is at 150hz (probably off on receiver). I only have time to listen for about 15 mins though. I need to put some time listening to my system to see if the crossover at 150hz is suitable. Other than that the graph looks better
Al,
Old 01-21-09, 04:41 AM   #25
Alias: Steven
thewire's Avatar
Loc: Midwest
User: #9828
Since: Jun 2007
  thewire is offline
That looks so much like the response I had from last month besides bellow 25Hz I am amazed. I moved the mains further from the seats and closer to the side walls, then checked phase, adjusted speaker distances.. The 80Hz crossover is a bit like having stereo subs and can be a bit distracting. I thought 100Hz was alright but 150Hz was really eating into my subs headroom. Are you aiming your mic directly up?
back, full, range, time
