| REW Forum why does my graph look like this??Discuss why does my graph look like this?? in the Equalization | Calibration forum; why does my graph look like this?? how to fix please........ |
Views: 487 - Replies: 7
| | #3 | ||||
| Re: why does my graph look like this?? I'm not the expert ...but Did you followed the step by step guide, specially calibrate SPL meter??? What subs are you measuring??? ...Use the correct graph (45db-105db and 15Hz-200Hz before the boss corrects you ) | ||||
| | #4 | ||||
| Re: why does my graph look like this?? Ummm...you need to explain your test setup and what you're measuring. Nevertheless, looks like you've got C-Weighting turned on. -Mike Bentz ~It's all about compromise~ "It's territorial with the soundboard. So you're mixing and some dude comes by spewing opinions and trying to turn knobs. It's akin to going up to an artist and painting over his unfinished masterpiece. You just want to shove your paint brush up his nose and throw the soundboard out the window!" | ||||
| | #5 | ||||
| Re: why does my graph look like this?? ![]() this better??? Is still upside down or something... Don't know why its not working....had it working last week. I simply clicked on REW icon and calibrated spl in mic-meter settings......am I supposed to do something else on start up??? I put 2 of my svs cs ultras dead center of the front wall and 2 dead center of back wall (I had all 4 in the back of the room before). So I now I need to re EQ with REW. ![]() | ||||
| | #6 | ||||
| Re: why does my graph look like this?? When you load REW you should get two pop ups saying that it's loading the microphone calibration and the sound card calibration. If you don't get those, you have to go the beginning and set the program up. Next....calibration....calibrate to 75db C slow using subwoofer cal signal Next, get rid of the mic/meter cal and soundcard cal by unchecking the boxes at the bottom. Then measure...subwoofer cal signal....first set levels...then measure. No trace adjustment/smoothing....or 1/3 octave Then post your results (filter adjust tab) | ||||
| | #7 | ||||
| Re: why does my graph look like this?? You have monitor mode in the soundcard turned on. It results in the line-in enabled in the Windows Playback Mixer. The looped internal signal is the mirror image of the meter calibration file as a result. brucek | ||||
