| REW Forum Galaxy CM-140Discuss Galaxy CM-140 in the Equalization | Calibration forum; Galaxy CM-140 I see this only goes down to 31.5 Hz? Am I correct? I would need to use the Radio Shack ... |
Views: 372 - Replies: 12
| | #2 | |||||
| Re: Galaxy CM-140 Quote:
brucek | |||||
| | #5 | ||||
| Re: Galaxy CM-140 The ECM8000 is the best setup but you still need a SPL meter to get proper levels set, The CM140 is quite a bit better then the RS meter. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #6 | ||||
| Re: Galaxy CM-140 Yeah, I would say the ECM and the CM-140 are both pretty good down to 10Hz. If you look at the correction files of the ECM and the CM-140, they're down ~-9dB and -10dB respectively. Below that they drop off pretty quick and you would be get into noise. The RS meters should only be used to about 15Hz. brucek | ||||
| | #7 | ||||
| Re: Galaxy CM-140 This graph looks pretty consistent which leads me to believe it is accurate way down low. I guess it really does not matter but am I flat to 5Hz or am I pushing it to say that? ![]() The was measured with a C-140. ![]() | ||||
| | #8 | |||||
You have to consider the amount of boost that the cal file offers at the lower frequencies. When we created the cal file for the Galaxy, we found them to be quite a good mic with very good consistency between units. The 5Hz entry required 24dBSPL boost. That's quite a lot. If the response of the meter has dropped off 24dB, you are starting to get into the noise floor. Personally, I wouldn't trust any meter below 10Hz... brucek | |||||
| | #10 | |||||
Post the impulse response so we can see. I just want to see how far down your noise is. Obviously if it's -30dBFS, we can assume the response it shows at 5Hz is noise. Again, either way, there's no usable information below about 10Hz, so I wouldn't be too concerned with anything below that. brucek | |||||
| | #12 | |||||
brucek | |||||
