REW Forum
Just hooked up REW and it haven't quite clicked..
Discuss Just hooked up REW and it haven't quite clicked.. in the Equalization | Calibration forum; Just hooked up REW and it haven't quite clicked.. I've have REW up and running. worked on it late last night so i could have been sleep and missed ...
Views: 306 - Replies: 13
Old 01-21-09, 04:43 PM   #1
Alias: dredre
User: #31931
Since: Jan 2009
  dredre is offline
I've have REW up and running. worked on it late last night so i could have been sleep and missed the vital details...
First things first... what is the proper range settings for the 33-2055?
I read on another post it should be set at "80" however, when I set it at 80 and "measure" it at the default 75. it says that the signal is too low... When I turn up the monitor volume the the SPL starts blinking. at 90... so should I increase the range? Or am I missing something?
Old 01-21-09, 05:10 PM   #2
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Re: Just hooked up REW and it haven't quite clicked..
Under "Settings," "Mic/Meter" tab, do you have the "C-weighted SPL meter" box checked? Also, did you download the correct calibration file for your SPL meter?
Old 01-21-09, 06:32 PM   #3
Alias: brucek
User: #6
  brucek is offline
Then you turn up the REW input level. This increases the level into REW, and doesn't change the 75dB on the SPL meter..
Old 01-21-09, 08:24 PM   #4
Alias: dredre
User: #31931
Since: Jan 2009
  dredre is offline
thx guys!!! i turned up the sound card input vol
before i start re-arranging the room....
arround the measured 38% spot... does this look normal???
Old 01-22-09, 01:50 AM   #5
Alias: Wayne
Loc: Katy, Texas
User: #8
Depends. Is this a measurement from the main speakers?
Old 01-22-09, 09:57 AM   #6
Alias: dredre
User: #31931
Since: Jan 2009
  dredre is offline
yes sir.. I don't have any subs... this is for a my lil studio... 11X9.5.x9
But that makes me wonder do i need subs in order to see/hear the full picture
Old 01-22-09, 11:36 AM   #7
Alias: brucek
User: #6
  brucek is offline
I don't know what that means, but if you're listening to music, you can usually get away without a sub, but not for movies.
Old 01-22-09, 12:30 PM   #8
Alias: dredre
User: #31931
Since: Jan 2009
  dredre is offline
ok... this would be for music...
i was thinking outloud... "do i need a sub for my studio or can i get by without"
sorry for the incomplete thought...
but as for the chart does that look normal... it would be at the 38% position of the room...
Old 01-22-09, 12:44 PM   #9
Alias: Wayne
Loc: Katy, Texas
User: #8
Not sure what a 38% position is, but the graph looks normal, as for as you doing everything right to get a good measurement. The response itself - as you can see, your speaker's bass response is fairly ragged.
Old 01-22-09, 01:11 PM   #10
Alias: dredre
User: #31931
Since: Jan 2009
  dredre is offline
oh... yea.. the 38% is a theory that you can get the best response for mixing 38% from the wall... it is nothing set in stone...but something i've seen on the net...
By being ragged.. i'm betting that means all over the place..hahha.. yea i'm planning on get some bass traps and some other forms of treatment soon.
Old 01-22-09, 01:31 PM   #11
Alias: Wayne
Loc: Katy, Texas
User: #8
Traps will decrease the time it takes low frequency signals to decay, which will tighten up the way the bass sounds. Treatments will reduce reverberation of the mid and upper frequencies by absorption or breaking up the sound waves. However, treatments and traps will not, as a "for instance," eliminate problems like the big hole you have at 75 Hz.
Old 01-22-09, 03:42 PM   #12
Alias: dredre
User: #31931
Since: Jan 2009
  dredre is offline
and i guessing could that be a result of speaker placement?
Old 01-22-09, 03:47 PM   #13
Alias: brucek
User: #6
  brucek is offline
Yep...........
Old 01-22-09, 03:51 PM   #14
Alias: dredre
User: #31931
Since: Jan 2009
  dredre is offline
Thx guys... i'll be back with some rearranging...and some updates
clicked.., haven't, hooked
