Hi all,
For my measurements I use the function "export impulse response as WAV" often. All good but, when I check the "export minimum phase version of IR" box, the behavior is not as expected:
1) FILE NAME
Usually the name is taken from the overlapping panels on the left, which is very useful. But having the "minimum phase" box activated the name is always set to "minPhase.wav". It would be great to have the name from the left overlapping panels also here... maybe with a suffix like -MP.
2) PEAK POSITION
Without the "minimum phase" option, the peak occurs exactly 1 second after the start which is just fine. Unfortunately, with "minimum phase" enable, the peak occurs somewhat earlier than 1 second and it varies between ca. 0,998s and 0,997s. I already tried to adjust the timing with the functions "Estimate IR Delay" and "t=0 offset(ms)" without success because they affect the non-minimum phase version only.
It would be great to get your support on this
1) FILE NAME
2) PEAK POSITION
