REW Forum
2 Channel guy with SET amp and Horns going to use REW - Suggestions wanted.
Discuss 2 Channel guy with SET amp and Horns going to use REW - Suggestions wanted. in the Equalization | Calibration forum; 2 Channel guy with SET amp and Horns going to use REW - Suggestions wanted. I have a 45 tube SET amp system with Horns in a dedicated 2 Channel system. I build some custom ...
Views: 303 - Replies: 5
Old 01-25-09, 07:42 PM   #1
New Member
Alias: Kevin
User: #32734
Since: Jan 2009
  Cut-Throat is offline
I have a 45 tube SET amp system with Horns in a dedicated 2 Channel system. I build some custom crossovers for it and my plan is to use REW to see if it looks as good on paper as it sounds. Or can the crossover be tweaked. I currently have Klispch Bass Bins and Tweeters with Altec 1005B horns and 288-16K drivers. They are crossed over at 400 hz and 6K hz. - I think - or that is what the formula said with the Cap values and inductor values I'm using.
I have an Extech SPL meter and have downloaded and read the REW help extensively. My plan is to buy a Creative external Sound card that has been mentioned and take some measurements. Am I on the right track in what I am trying to do?
Suggestions Welcome!
Old 01-26-09, 07:25 AM   #2
Alias: brucek
User: #6
  brucek is online now
Re: 2 Channel guy with SET amp and Horns going to use REW - Suggestions wanted.
You would require a calibration file for the Extech meter. Most Extech meters appear to be of good quality, so I suspect it's full range, but you would require a cal file to compensate for the upper and lower end. If you were just checking the crossovers, I suppose you could get away without it.
Old 01-26-09, 07:49 AM   #3
New Member
Alias: Kevin
User: #32734
Since: Jan 2009
brucek wrote: View Post
OK, I am confused a little here. I though that I just calibrated my SPL meter in the REW program. If I need to get a file, where might I get one?
Old 01-26-09, 09:34 AM   #4
Alias: brucek
User: #6
Both the soundcard and the meter require compensation for their inadequacies.
The soundcard is taken care of by running a routine that measures the response over a loopback cable and a calibration file is created.
That obviously isn't possible for the meter, so a calibration file is required to be loaded into REW. There are a few ways to get a calibration file. You can get the meter/microphone calibrated at a lab. You can use a generic file that we supply on our Download Page if you are using a Radio Shack, Galaxy or Behringer meter/mic. You can create a file from a frequency response chart over the bandwidth supplied on the chart.
Read and become familiar with the REW HELP files and the REW Cabling and Connections Basics.
Also note the REW information Index
Old 01-27-09, 07:11 PM   #5
Alias: Mike Bentz
DrWho's Avatar
Loc: Chicago
User: #2782
Since: Sep 2006
  DrWho is offline
Did your SPL meter come with a calibration curve?
I didn't look it up, but someone mentioned you have a nice one...the really really nice ones always come with a frequency response (and polar response) of the microphone's performance.
If you were creative, you could get by with a super jagged and unknown meter frequency response, but it would change how you interpret the measurements (and require some extrapolation).
-Mike Bentz
~It's all about compromise~
"It's territorial with the soundboard. So you're mixing and some dude comes by spewing opinions and trying to turn knobs. It's akin to going up to an artist and painting over his unfinished masterpiece. You just want to shove your paint brush up his nose and throw the soundboard out the window!"
Old 01-27-09, 07:15 PM   #6
New Member
Alias: Kevin
User: #32734
Since: Jan 2009
DrWho wrote: View Post
I have an Extech Model 407727 - I don't think it came with a curve.
I can't even buy the Creative Sound Card anymore! - Seems like it's out of production.
channel, horns, suggestions, wanted.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332
