REW Forum
REW for nearfield monitors
Discuss REW for nearfield monitors in the Equalization | Calibration forum; REW for nearfield monitors Hi Guys, Im looking to use REW for evaluating a stereo system in a studio. I just did a bunch ...
Views: 363 - Replies: 13
Old 01-27-09, 06:32 AM   #1
Alias: timos
User: #32731
Since: Jan 2009
  dodittydada is offline
Hi Guys,
Im looking to use REW for evaluating a stereo system in a studio. I just did a bunch of tests and ran into some problems.
First of all, target settings were set to sub woofer, so I guess that voids the tests, so no graphs psoted here!
Secondly , I ran both speakers for the test. Should I just be doing one? Or both bot one at a time? thanks.
Old 01-27-09, 06:45 AM   #2
Alias: timos
User: #32731
Since: Jan 2009
Re: REW for nearfield monitors
also, I read here some say to point at the speaker, others say to point straight up from the listening position. Whats correct?
Old 01-27-09, 08:40 AM   #3
Alias: brucek
User: #6
  brucek is online now
You could do them one at a time, then together to check cancellations between the two. Since you won't have much leeway in your seating position at the board, the position of the monitors and room treatment can be adjusted for the smoothest response.
We don't know what you're pointing.
Old 01-27-09, 06:08 PM   #4
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
dodittydada wrote: View Post
What brucek said. If you're using a Behringer ECM8000 with our calibration file, the file was generated with the mic pointing up. If you're using some other mic, the orientation should likewise be the same as was calibrated for.
Old 01-28-09, 12:04 AM   #5
Alias: timos
User: #32731
Since: Jan 2009
guys Im using the RS SPL meter/mic 33 4050. So, point up or head on slightly off axis? sorry bout that minor detail missing ) ...
Old 01-28-09, 06:05 PM   #6
Alias: Wayne
Loc: Katy, Texas
User: #8
For subwoofer measurements, it really doesn't make any difference. For full range measurements I'd point it at the speaker (keeping in mind that it isn't accurate beyond ~3kHz).
Old 01-29-09, 12:38 AM   #7
Alias: ElectroKinetic
Loc: Chicago
User: #32218
Since: Jan 2009
  ElectroKinetic is offline
Are you referring to the RS meter not being accurate above 3khz?
Old 01-29-09, 11:31 AM   #8
Alias: brucek
User: #6
Yes, that would be its upper limit of accuracy....
Old 01-29-09, 12:09 PM   #9
Loc: Chicago
User: #32218
Since: Jan 2009
Is the behringer measurement mic more accurate?
Old 01-29-09, 12:20 PM   #10
Alias: brucek
User: #6
Yes, with a cal file, it can be used from 10Hz to 20000Hz.
Old 01-29-09, 12:42 PM   #11
Loc: Chicago
User: #32218
Since: Jan 2009
I'll definitely have to pick one up. Thanks Brucek!
Old 01-29-09, 12:57 PM   #12
Alias: brucek
User: #6
And it also requires a mic preamp to operate.....
Old 01-29-09, 01:26 PM   #13
Loc: Chicago
User: #32218
Since: Jan 2009
Does it require phantom power?
Old 01-29-09, 01:38 PM   #14
Alias: brucek
User: #6
Yes.......
monitors, nearfield
