| REW Forum A few new measurementsDiscuss A few new measurements in the Equalization | Calibration forum; A few new measurements I measured these with my new C-140 meter. The results are very similar to what I got with the RS ... |
Views: 331 - Replies: 3
| A few new measurements I measured these with my new C-140 meter. The results are very similar to what I got with the RS meter but different. As a reminder this is 2 HSU ULS-15's in a sealed 1800 cubic foot room. First the Sub only: Red is with No Audyssey Green is with Audyssey on Blue is with Audyssey on and Dynamic EQ on. This is with a cross over of 80 and the sub limit at 120 It appears Audyssey is cutting my output below 14 Hz? It also appears that the subs without Audyssey are flatter? Any thought on this? I tried to put a target line in but was unable to. ![]() Here is a waterfall of the sub only same crossover as above with Audyssey and Dynamic volume on. It is the "worst" of the three waterfalls. Again, any thoughts? ![]() I have 3 possible positions for my subs, they are not very far apart but I thought I would try each to see if there is a significant change in the response. Finally I did some measurements with my mains and kept getting a clipping warning? How can I address this? Did I try and measure to low, 45 Hz? I'd like to get a clean reading from the mains also. Thanks Bill | ||||
| | #2 | ||||
| Re: A few new measurements Here are some additional views The first is with Audyssey on with the target curve. Seeing it this way Audyssey does a pretty good job. ![]() Here is Audyssey on and Dynamic EQ on which is there version of a house curve. My understanding is that they are attempting to bring the full range of sound at less then reference volume levels. ![]() I have been listening with Dynamic EQ on and in some movies the bass becomes heavy. Sometimes this can be heard in music other is the effects. In those cases I turn Dynamic EQ off. | ||||
| | #3 | ||||||
| Re: A few new measurements Quote:
If it's sub plus mains over 15Hz-200Hz, use the sub test signal. If you get a clipping warning, reduce the input level and rerun the Calibrate routine. brucek | ||||||
| | #4 | ||||||
Regards, Wayne | ||||||
| Bookmarks |
| Tags |
| measurements |
| Thread Tools | |
