| REW Forum REW on OS X 10.5 and DIgidesign MboxDiscuss REW on OS X 10.5 and DIgidesign Mbox in the Equalization | Calibration forum; REW on OS X 10.5 and DIgidesign Mbox Hi Guys,
I try to use REW on OS X 10.5.6 with an external USB audio interface (Digidesign Mbox). No ... |
Views: 689 - Replies: 10
| REW on OS X 10.5 and DIgidesign Mbox Hi Guys, I try to use REW on OS X 10.5.6 with an external USB audio interface (Digidesign Mbox). No matter what settings I choose in REW, System Preferences or Audio MIDI Setup, REW doesn't use the Mbox as an input device although it's selectable in REW's input device list. REW always uses the internal microphone of my MacBook Pro. Any ideas how to fix this? Java Preferences are set to JSE 5.0. Thanks for your help, Markus | ||||
| | #2 | ||||
| Re: REW on OS X 10.5 and DIgidesign Mbox For the longest time, I had to always manually select my M-Audio MobilePre in REW to use it for in and out device. It defaulted to the internal soundcard. I honestly forget what I changed, but I think it was a Windows setting, not REW or Java. Doesn't help you directly, but the problem may be with the computer settings. We've got a few OSX people here, hopefully one of them will chime in. And Welcome to the Shack! ![]() | ||||
| | #3 | ||||
| Re: REW on OS X 10.5 and DIgidesign Mbox I believe that on some MacBooks the internal mic is always active, at least for Java apps, so you have to set the mic volume to zero in the Audio Midi preferences as well as selecting the Mbox as the default input. | ||||
| | #4 | ||||
| Re: REW on OS X 10.5 and DIgidesign Mbox I remember seeing a post a few months back when I was trying to get this same thing figured out that said you can't use an Mbox. I think the Digidesign stuff is all proprietary and only works with Pro Tools software. | ||||
| | #5 | ||||
| Re: REW on OS X 10.5 and DIgidesign Mbox JohnM, thanks but it looks like JAVA overrides the settings in Audio MIDI Setup. "Default Input" always switches back to "Built-in Microphone" when REW is started. Has anybody ever managed to get REW running on a Mac with an external USB or Firewire audio device?? fsrenduro, you can use Digidesign hardware with any software on a Mac when the Digidesign CoreAudio Driver is installed. Best, Markus | ||||
| | #6 | ||||
| Re: REW on OS X 10.5 and DIgidesign Mbox External USB works fine with 10.5, Apple fixed a bug that exists in 10.4 that prevents Java apps seeing USB soundcard inputs, but the same issue still seems to affect Firewire soundcard inputs. | ||||
| | #7 | ||||
| Re: REW on OS X 10.5 and DIgidesign Mbox What USB device did you use to test REW on OS X? I'm using 10.5.6 which is the most current OS version on a MacBook Pro (MacBookPro5,1). Digidesign's MBox is a USB device (see "http://www.digidesign.com/index.cfm?navid=134&itemid=2620&langid=1") Best, Markus | ||||
| | #8 | ||||
| Re: REW on OS X 10.5 and DIgidesign Mbox I used an Edirol UA-1A I have lying around (modified to remove the internal loopback). | ||||
| | #10 | ||||
| Re: REW on OS X 10.5 and DIgidesign Mbox No, just plugged it in. | ||||
| Bookmarks |
| Tags |
| 10.5, digidesign, mbox |
| Thread Tools | |
