| REW Forum Computer in room 1/2 floor down from theaterDiscuss Computer in room 1/2 floor down from theater in the Equalization | Calibration forum; Computer in room 1/2 floor down from theater I really want to jump into REW. Any problems with running the cables to the theater room and not having ... |
Views: 286 - Replies: 4
| Computer in room 1/2 floor down from theater I really want to jump into REW. Any problems with running the cables to the theater room and not having the computer in the same room? I do not own a laptop and do not want to move my computer around. I am planning to run an xlr cable for the mic from the xenyx802 to the seating area from downstairs (roughly 50'), plus I will need to run rca's from the sound card to my processor in the theater (roughly 35'). All of the other connections will be in the computer room (unless I am missing something)?? Please feel free to chime in if I am. Since I have not had a chance to run any measurements (don't own any of the equipment yet), anybody foresee problems with theater/computer not being in the same room? It is half of a flight of stairs to the tv, so I can run back and forth fairly easily. Just don't know how important it is to have the computer right there. Plus, my desktop has a decent sound card. As for BFD - I may hold off on that till I see what the upcoming Outlaw Trinnov processor is released and I see the before and after results. | ||||
| | #2 | ||||||
| Re: Computer in room 1/2 floor down from theater Quote:
Then you go back to the computer to run the Calibrate routine, and then Measure.... The only noise you'll have to be concerned with is the one RCA from line-out to the computer, but it should be fine. brucek | ||||||
| | #3 | ||||
| Re: Computer in room 1/2 floor down from theater Thanks brucek! The diagram shows 2 splits from the line out on the sound card. from the first split one loops back to the line in and the other goes to another split so that i could feed a left and right input on the processor. is that second split not needed (just feed the left or right speaker)? | ||||
| | #4 | ||||||
There is a Y-splitter at the receiver to split (if you want) the mono signal to feed both left and right mains speakers for testing. Quote:
brucek | ||||||
