| REW Forum REW newbDiscuss REW newb in the Equalization | Calibration forum; REW newb Hello,
REW newb, what am what does it look like I am doing wrong here:
I have loaded the RS ... |
Views: 380 - Replies: 9
| REW newb Hello, REW newb, what am what does it look like I am doing wrong here: I have loaded the RS meter corrections in, I have calibrated SPL meter and sound card, why do my graphs continue to look like this. They do not look like others' graphs. Thanks Pioneer VSX-1018AH Sony BDP-S550 Polk Audio TSi 500 - L/R Polk Audio TSi CS20 - C Polk Audio Monitor50 - SR/SL JBL J2080 - SBR/SBL 2 x SVS PB13-ULTRA / 2 x PC13 - Ultra 110 sq ft room Feel the SVS! | ||||
| | #3 | ||||
| Re: REW newb Here it is Pioneer VSX-1018AH Sony BDP-S550 Polk Audio TSi 500 - L/R Polk Audio TSi CS20 - C Polk Audio Monitor50 - SR/SL JBL J2080 - SBR/SBL 2 x SVS PB13-ULTRA / 2 x PC13 - Ultra 110 sq ft room Feel the SVS! | ||||
| | #5 | ||||
| | #6 | ||||
| Re: REW newb That's not a vertical scale of -3dB to +3dB, but you can certainly see how that isn't a good calibration. That's just noise. Rerun the calibration routine for the soundcard. Be sure you have a single cable from the right line-out to right line-in, and have the proper setup levels of -12dB on both VU out and meters. brucek | ||||
| | #7 | ||||
| Re: REW newb How does this look, it looks more like one of the examples in the help file. Pioneer VSX-1018AH Sony BDP-S550 Polk Audio TSi 500 - L/R Polk Audio TSi CS20 - C Polk Audio Monitor50 - SR/SL JBL J2080 - SBR/SBL 2 x SVS PB13-ULTRA / 2 x PC13 - Ultra 110 sq ft room Feel the SVS! | ||||
| | #8 | ||||
| Re: REW newb Well I tried to do a measure and still the graph looks nothing like others'. Could it be something in the sound card mixer. It is an aftermarket souncars, I have: microphone(playback) /aux / analog mix(options are mic mute, aux mute) / midi synth / spdif-in / digital-in / REC(options: spdif-in, digital-in, microphone, analog mix). It also has an audio creation mode. Would it be worthwhile to uninstall this souncard and install the motherboard sound drivers, it might simplify things? Pioneer VSX-1018AH Sony BDP-S550 Polk Audio TSi 500 - L/R Polk Audio TSi CS20 - C Polk Audio Monitor50 - SR/SL JBL J2080 - SBR/SBL 2 x SVS PB13-ULTRA / 2 x PC13 - Ultra 110 sq ft room Feel the SVS! | ||||
| | #9 | ||||||
| Re: REW newb Quote:
The example below is how it should look. ![]() Quote:
Recording Mixer ![]() Playback Mixer ![]() brucek | ||||||
| | #10 | ||||
| Re: REW newb I am running Vista 64bit not XP. I found a review you did on an external souncard and followed that but alas not go. I ended up uninstalling soundcard drivers and using the onboard sound but still struggling. I think I will go back to the aftermarket sound card and give that another try. Pioneer VSX-1018AH Sony BDP-S550 Polk Audio TSi 500 - L/R Polk Audio TSi CS20 - C Polk Audio Monitor50 - SR/SL JBL J2080 - SBR/SBL 2 x SVS PB13-ULTRA / 2 x PC13 - Ultra 110 sq ft room Feel the SVS! | ||||
