REW Forum
RS SPL Meter + soundcard OR Behringer ECM800 + mic preamp
Discuss RS SPL Meter + soundcard OR Behringer ECM800 + mic preamp in the Equalization | Calibration forum; RS SPL Meter + soundcard OR Behringer ECM800 + mic preamp I am a newb and want to get the room response and the integration between my subwoofer and main speakers. ...
Views: 750 - Replies: 8
Old 02-14-09, 06:58 PM   #1
Alias: Don
Loc: Flordia
User: #8305
Since: Apr 2007
  ddemeterio5 is offline
I am a newb and want to get the room response and the integration between my subwoofer and main speakers. Is it enough to use a Soundblaster Live card + Radioshack SPL meter? How accurate are these readings? Or do I need to step up to Behringer ECM8000 + Edirol UA25EX setup?
What are the pros and cons between the two methods? Any differences in setup procedure and hooking up?
Old 02-14-09, 07:05 PM   #2
Alias: brucek
User: #6
  brucek is online now
Re: RS SPL Meter + soundcard OR Behringer ECM800 + mic preamp
The RS meter is fine for subwoofer and mains at the low end, and a suitable for home use.
As far as setup, read and become familiar with the REW Cabling and Connections Basics and the REW HELP files.
Also note the REW information Index and the Download Page.
Old 02-14-09, 07:21 PM   #3
Alias: Don
Loc: Flordia
User: #8305
Since: Apr 2007
I am using the 33-4050 model. I have read that they are not so accurate from 50 Hz and below. Is this true? If so, then how can I get an accurate reading? Should I get a good quality SPL meter instead? any recommendations?
Old 02-14-09, 07:31 PM   #4
Alias: brucek
User: #6
Yep, read the information I linked for you, and you would find that we offer free calibration files that render the meter flat down to 10Hz.
Old 02-14-09, 07:38 PM   #5
Alias: Don
Loc: Flordia
User: #8305
Since: Apr 2007
Cool.
How about the sound card? I'm going out to purchase a sound card, what's the best for under $200?
Old 02-14-09, 09:21 PM   #6
Alias: Don
Loc: Flordia
User: #8305
Since: Apr 2007
The reason I ask is because I don't have a sound card and the Sound Blaster Live is discontinued. I'm looking for a very good sound card because I also use it to connect my laptop to my stereo. Any recommendations?
Old 02-18-09, 10:45 AM   #7
New Member
Alias: Rich
Loc: S.W. Michigan USA !!
User: #20066
Since: Apr 2008
  MaxCast is offline
I am too looking for an updated sound card for use with REW.
I would require an external card. Will anything with audio RCA outs/ins work?
Thanks
Old 02-18-09, 12:10 PM   #8
Alias: brucek
User: #6
Yeah, pretty much.......... there are many, many to choose from, cheap or expensive....
Old 02-18-09, 04:20 PM   #9
New Member
Alias: Rich
User: #20066
Since: Apr 2008
  MaxCast is offline
Thank you, Bruce.
behringer, ecm800, meter, preamp, soundcard
