Measuring Drivers Distance - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 7 Old 05-06-17, 04:50 PM Thread Starter
Jay Compton's Avatar
jcmusic
Now I know the distance from the mic to the speaker should be 1 meter, now is that 1 meter from the front of the speaker cabinet? Or 1 meter from the horn or the drivers mouth??? This measurement should be performed on speaker at a time to see what both speakers are doing correct? The after making adjustments to get both speakers doing the same thing then measure from the listening position..
Jay Compton is offline
post #2 of 7 Old 05-07-17, 07:17 PM
HTS Moderator
ajinfla's Avatar
AJ
Re: Measuring Drivers Distance
If you are measuring the speakers native response, yes 1m from baffle.
Generally speaking, this should need no EQ. However no laws are broken doing so, so if it pleases your ears...
At the LP, you will be measuring both with room effects included. Again, generally speaking, you should only EQ below 400hz or so. Mainly cutting any large peaks...but be aware that applies to the position where the mic is. This means you've created a hole somewhere else...which may not matter unless you sit there also.
cheers
AJ
ajinfla is offline
post #3 of 7 Old 05-09-17, 06:21 AM Thread Starter
jcmusic
Hey AJ,
Thanks for replying what do you mean by baffle?
Jay
post #4 of 7 Old 05-09-17, 08:45 AM
HTS Moderator
ajinfla's Avatar
AJ
The front wall of speaker enclosure is considered the baffle, where the drivers are usually mounted.
So for example, with a 6" 2 way, you would place the mic 1m from baffle/front plane of speaker, height of mic pointed between the bottom edge of tweeter and upper edge of woofer. That should give you a decent idea of the speakers native response, using quasi-anechoic measurements as you are doing. Good enough for Gov work ;-)
cheers
AJ
ajinfla is offline
post #5 of 7 Old 05-09-17, 08:24 PM Thread Starter
jcmusic
Ok AJ thanks, now my drivers are about 24" from the baffles. So I should move the mic closer to get to one meter correct?
post #6 of 7 Old 05-10-17, 10:22 AM
HTS Moderator
ajinfla's Avatar
AJ
Your drivers should be mounted in the baffles, aka, front face of loudspeaker. Mic should be around 36" away
AJ
ajinfla is offline
post #7 of 7 Old 05-10-17, 07:04 PM Thread Starter
jcmusic
ajinfla wrote: View Post
AJ to clarify I have klipsch corner horns and the actual driver is all the way to the back the horn is very long, so do I measure from the horn where it meets the baffle? Or from the drivers voice coil?
distance , drivers , measuring
