Acoustic timing reference with UMIK1 - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 2 Old 06-13-17, 07:44 PM Thread Starter
New Member
First post newbie here I am just getting started on measuring my system and at some stage I will want to align the timing on at least the L/C/R/SW's and will need to use a timing reference.
My measurement setup is a UMIK1 mic for input and Behringer UCA222 for output. The left output is connected to the left input on my pre-pro Aux input. I can select a "party" effect and send the same signal to all the speaker channels and by using the balance control and turning on the appropriate power amplifier, I can isolate the desired speaker. I have set it up this way because, like most people, I want to avoid swapping cables around all the time.
I understand that with the UMIK1, I need to use an acoustic timing reference. Is it OK to use a portable powered speaker (i.e. UE Boom) connected to the UCA222 right output for producing that signal? It would be handy if the internal speaker on the laptop could be used but I imagine there are good reasons that would be problematic.
TIA
dylansj is offline
post #2 of 2 Old 06-14-17, 08:52 AM
REW Author
JohnM's Avatar
John
Re: Acoustic timing reference with UMIK1
Yes, you could use another speaker for the timing ref. Just make sure to keep it in the same place relative to the mic for all your measurements.
JohnM is offline
acoustic , reference , timing , umik1
