REW Forum
first measurement
Discuss first measurement in the Equalization | Calibration forum; first measurement Have at last managed to hopefully done a correct measurement can someone please have a look and advise. Thanks James ...
Views: 303 - Replies: 6
Old 02-21-09, 08:07 AM   #1
Alias: James
Loc: scotland
User: #4512
Since: Nov 2006
  James Morrison is offline
first measurement
and advise.
Thanks
James Morrison
Old 02-21-09, 09:37 AM   #2
Alias: brucek
User: #6
  brucek is online now
Re: first measurement
Can't say much until we see your sub only with the mains disconnected.
Old 02-21-09, 11:07 AM   #3
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Yeah, a sub-only graph would be nice, but as it sits now you have a pretty huge (25 dB +) spread between your highest peak (~35 Hz) and your lowest depression (~65 Hz). Probably doesn't sound that good...
Try some different locations for your sub, if that's an option, and see if you can find one that minimizes the peaks and valleys.
Old 02-21-09, 12:42 PM   #4
Alias: James
Loc: scotland
User: #4512
Since: Nov 2006
Here is one with sub only have tried moving sub around room but always with the same results not much bass in the mid regions but loads at the bottom end.
Old 02-21-09, 01:23 PM   #5
Alias: brucek
User: #6
You'll certainly need an equalizer to reduce the wide peak between 20Hz-40Hz. Then you'll be able to increase the wholesale gain of the sub to bring up the result to the target line. Then add the mains and see how it looks.
Old 02-21-09, 03:26 PM   #6
Alias: James
Loc: scotland
User: #4512
Since: Nov 2006
thanks for looking, will reduce peak between 20 & 40 first, not sure how to increase the wholesale gain of sub though, will take it one step at a time reduce peaks then post results and get information on increasing gain if thats ok
Thanks
James Morrrison
Old 02-21-09, 04:14 PM   #7
Alias: brucek
User: #6
Turn up the subwoofer amp volume control...........
measurement
