Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Equalization | Calibration > REW Forum
REW Forum
  Discuss First time, some help needed in the Equalization | Calibration forum; First time, some help needed Hello, I did the setup for the mic and the sound card. I then ran my sub only at 80hz ...
Views: 664 - Replies: 32
Old 02-21-09, 08:18 PM   #1
Alias: Rick
Loc: Green Bay
User: #6523
  rick12667 is offline
Hello,
I did the setup for the mic and the sound card. I then ran my sub only at 80hz and here is my first try. Can you tell me how this looks and what needs to be done?
Thanks Rick
Old 02-21-09, 08:42 PM   #2
Shack Moderator
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Re: First time, some help needed
Please re-scale your graph for a 15-200 Hz horizontal and 45-105 dB vertical axis. You can do that by clicking on the "Graph Limits" icon in the upper right corner.
Old 02-21-09, 09:06 PM   #3
Alias: Rick
Loc: Green Bay
User: #6523
how about this?
Old 02-21-09, 09:55 PM   #4
Alias: brucek
User: #6
  brucek is offline
You're going to have to move your sub around the room a bit to try and smooth that response out. It doesn't look too good where it is.
Old 02-21-09, 10:03 PM   #5
Shack Moderator
Alias: Wayne
Loc: Katy, Texas
User: #8
Yeah, I'd call that response "unequalizable" - so bad even an EQ can't fix it. Typically you want response to be in about a 15 dB window between the worst peaks and dips. You have nearly twice that...
Old 02-22-09, 07:19 AM   #6
Alias: Rick
Loc: Green Bay
User: #6523
This is showing two tempest X subs. I don't have the ability to move the subs as they are built into my front walls. There is one sub on each side of the front stage. Should I run them seperate and see how they look?
Old 02-22-09, 08:27 AM   #7
Alias: Rick
Loc: Green Bay
User: #6523
OK I ran a few test this morning running both subs at different Hz levels and in different phases. Here is the best that I could come up with. Two subs at 100hz reverse phase. Both subs are being driven by a Europower EP2500 amp so not sure if I can do anything with the amp to help change this. Give me some feedback please. Also here is a pic of the front of my room so you can see that I am not able to move the subs.
Thanks Rick
Old 02-22-09, 08:56 AM   #8
Alias: brucek
User: #6
  brucek is offline
One of the best things for in wall IB mounts is to first check out the locations acoustically.
That is not a good response. It is not equalizable in my opinion.
Try one IB at a time and see if either is the culprit, or is it only when they play together that the trouble begins.
Old 02-22-09, 09:12 AM   #9
Alias: Rick
Loc: Green Bay
User: #6523
OK I ran each sub seprate at 100hz in both normal and reverse pahse. Here is the results
Old 02-22-09, 10:16 AM   #10
Alias: Rick
Loc: Green Bay
User: #6523
Here is a breakdown using 100HZ
Red = Speaker only at 100hz
Green = Sub only at 100hz phase reverse
Blue = Both sub and speakers at 100hz
needed, time
Bookmark and Share
Dish Network
