REW Forum
Waterfall Plot Perspective Control (Turn Off?)
Discuss Waterfall Plot Perspective Control (Turn Off?) in the Equalization | Calibration forum; Waterfall Plot Perspective Control (Turn Off?) I've read the manual explanations of the perspective control sliders, but I am wondering if I am missing this functionality: ...
Views: 334 - Replies: 7
Old 02-23-09, 11:35 AM   #1
New Member
Alias: Chris Gray
User: #33916
Since: Feb 2009
  cray54 is offline
Can perspective be turned off entirely while maintaining a 3D plot in the Room EQ Wizard?
Thanks, Chris
Old 02-23-09, 12:15 PM   #2
Alias: brucek
User: #6
  brucek is offline
Re: Waterfall Plot Perspective Control (Turn Off?)
I don't quite understand what you want to do.
The ON/OFF perspective button will shut off the plane associated with it, but generally you want the waterfall to be viewed in 3D with all buttons ON.
The best settings for X, Y, Z would be X=1, Y=50, Z=150.
Be sure the LOG view is selected and not the LIN view.
Use the same standard Vertical graph axis of (45dB - 105dB) and the Horizontal graph axis of (15Hz - 200Hz) that is used for your response graphs.
Old 02-23-09, 12:38 PM   #3
New Member
Alias: Chris Gray
User: #33916
Since: Feb 2009
  cray54 is offline
brucek,
I do still want 3D graphs. The best example I could find regarding my perspecive question is this:
(Public domain, from wikimedia.org)
I'd like my graphs to be like 'A' but they are currently like 'B' (I'd like my vanishing points to be infinitely far away).
Thanks,
Chris
Old 02-23-09, 01:22 PM   #4
Alias: brucek
User: #6
  brucek is offline
Well, I don't really understand vanishing points, but the waterfalls provided in REW are the standard that everyone uses.
You can play with the X, Y and Z and get it the best you can.
Old 02-23-09, 01:58 PM   #5
New Member
Alias: Chris Gray
User: #33916
Since: Feb 2009
  cray54 is offline
Adjusting the sliders does not allow one to eliminate the perspective without flattening the image.
It seems to me the standard in audio books and most programs is the style graph I am describing. I was just trying to figure out how to make the program graph the way that seemed most conventional.
-Chris
Old 02-23-09, 02:02 PM   #6
Alias: brucek
User: #6
  brucek is offline
Could you show us that, so I know what you're talking about?
What is it on the waterfall that you want to see, that you can't see. It's shows the decay in time slices, that's about it...
Old 02-23-09, 03:02 PM   #7
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
No, you cannot remove the depth effect. It was a personal preference to generate the plots as they are, but I can add an option to eliminate the perspective to the feature request list.
Old 02-23-09, 07:09 PM   #8
New Member
Alias: Chris Gray
User: #33916
Since: Feb 2009
  cray54 is offline
John,
Thanks for the info, I'd really like that to be an option. Also, I figured I'd let you know, I really like the easy zoom and pan capability of the graphics. It makes navigating quite easy.
brucek wrote: View Post
brucek (for your reference),
If you search google images for “waterfall plot” you will find several plots that look more like image ‘A’ than image ‘B’. An example of what I’m talking about with REW is shown below:
In this image, Y1 = Y2 and X1 = X2 in value, but not in distance. I’m interested in making the distances Y1 = Y2 and X1 = X2.
Thanks,
Chris
(turn, control, off?), perspective, plot, waterfall
