| REW Forum Java errorDiscuss Java error in the Equalization | Calibration forum; Java error Hello all,
I'm a complete beginner in this and after downloading 4.11 I have a java error
I'm using Xp ... |
Views: 338 - Replies: 12
| Java error Hello all, I'm a complete beginner in this and after downloading 4.11 I have a java error I'm using Xp Sp3 and java 6-12 here's the log of the error, thanks for the help ---------------------------------------------------------------------------- Exception during startup Message: java.lang.RuntimeException: java.io.IOException: Could not get shell folder ID list Level: SEVERE Stack Trace: java.io.IOException: Could not get shell folder ID list sun.awt.shell.Win32ShellFolderManager2$ComInvoker.invoke(Unknown Source) sun.awt.shell.Win32ShellFolder2.getFileSystemPath(Unknown Source) sun.awt.shell.Win32ShellFolder2.composePathForCsidl(Unknown Source) sun.awt.shell.Win32ShellFolder2.<init>(Unknown Source) sun.awt.shell.Win32ShellFolderManager2.get(Unknown Source) sun.awt.shell.ShellFolder.get(Unknown Source) sun.swing.WindowsPlacesBar.<init>(Unknown Source) com.sun.java.swing.plaf.windows.WindowsFileChooserUI.updateUseShellFolder(U nknown Source) com.sun.java.swing.plaf.windows.WindowsFileChooserUI.installComponents(Unkn own Source) javax.swing.plaf.basic.BasicFileChooserUI.installUI(Unknown Source) com.sun.java.swing.plaf.windows.WindowsFileChooserUI.installUI(Unknown Source) javax.swing.JComponent.setUI(Unknown Source) javax.swing.JFileChooser.updateUI(Unknown Source) javax.swing.JFileChooser.setup(Unknown Source) javax.swing.JFileChooser.<init>(Unknown Source) javax.swing.JFileChooser.<init>(Unknown Source) roomeqwizard.o$34.<init>(Unknown Source) roomeqwizard.o.I(Unknown Source) roomeqwizard.o.<init>(Unknown Source) roomeqwizard.UA.<init>(Unknown Source) roomeqwizard.RoomEQ_Wizard.main(Unknown Source) sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) java.lang.reflect.Method.invoke(Unknown Source) jexepackboot.run(Unknown Source) jexepackboot.main(Unknown Source) Could not get shell folder ID list sun.awt.shell.Win32ShellFolder2.getFileSystemPath0(Native Method) sun.awt.shell.Win32ShellFolder2.access$900(Unknown Source) sun.awt.shell.Win32ShellFolder2$8.call(Unknown Source) sun.awt.shell.Win32ShellFolder2$8.call(Unknown Source) java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source) java.util.concurrent.FutureTask.run(Unknown Source) java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source) java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) sun.awt.shell.Win32ShellFolderManager2$ComInvoker$3.run(Unknown Source) java.lang.Thread.run(Unknown Source) | ||||
| | #2 | ||||
| Re: Java error This is a bug in Java's Swing library, see http://bugs.sun.com/bugdatabase/view...bug_id=6544857 It may be caused by shell folder paths that point to locations that do not exist. If you are comfortable with Regedit you can look at the keys in HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders And make sure that the paths do not point to non-existent or not accessible locations, e.g. a drive that is not connected or another user's folders. Some examples are shown in the Sun Bug entry. | ||||
| | #4 | ||||
| Re: Java error Hello again.... The java blog is quite clear on this, it's been known for 2 years and the bug is still unsolved... I've tried the workarounds described but nothing works... I guess that REW will have to do without me for the time being ![]() I'll try with the next java update and hope these idiots will solve it, to me they look as bad as MS right now ![]() Thanks for the help and I hope i can bother you guys soon with my problems... | ||||
| | #5 | ||||
| Re: Java error There is a way to disable use of shell folders by the file chooser, it may help. I'll put an option for that in the V5 release (but that is some way off, sorry). | ||||
| | #6 | ||||
| Re: Java error Thanks for the help, I'll be waiting for the next release. Just for my information why does java need to know where my documents are stored to be able to run (on top of this when it knows it it won't run properly...) Hope to hear from you soon JC | ||||
| | #7 | ||||
| Re: Java error have you tried uninstalling java completely and then re-installing. when i say uninstall i mean first run the uninstall program and then remove the java's runtime environment from the registry manually? here is a link that may be beneficial. hope it helps. | ||||
| | #8 | ||||
| Re: Java error Well to be honest I had a FW problem and I had to reformat (eset destroyed the network and there was no way out....) so you can say that yes I removed java and it didn't help... Is there a "quick and dirty" fix to be done on the REW that i can try or just wait fo the next release ? Thanks | ||||
| | #9 | |||||
| Re: Java error Quote:
| | #10 | ||||
| Re: Java error Not that I am aware of, sorry. | ||||
| | #11 | |||||
The firewall is quite good but it installs some miniports in the system to redirect the IP streams. When one of these crashes (the miniport) you cannot remove it because "it is needed by windows to start" and it lockes the complete network (no wifi, no RJ, no BT, no 1394...) And because they use an MSI to install you HAVE to keep the original MSI file to remove, which I didn't.... So basically a great product, using an installer which makes it impossible to remove without killing the registry ![]() | |||||
| | #12 | ||||
| Re: Java error So I'll wait for the "long and clean" fix ![]() However because of this my sound will be poor, my wife will divorce and I will commit suicide, but I'm not putting any pressure of course..... | ||||
| | #13 | |||||
