REW Forum
Soundcard Cal File
Discuss Soundcard Cal File in the Equalization | Calibration forum; Soundcard Cal File Can the soundcard cal file be transferred between PC's or does it need re-running if a different PC is used? ...
Views: 299 - Replies: 4
Old 02-23-09, 09:59 PM   #1
Alias: Mark
User: #33866
Since: Feb 2009
  BritInVA is offline
Soundcard Cal File
Cheers,
Mark
Old 02-23-09, 10:20 PM   #2
Alias: bigbadbill
Loc: Newcastle NSW
User: #26128
Since: Sep 2008
  robbo266317 is offline
Re: Soundcard Cal File
It will need to be re-run as it is machine specific.
Simple to do anyway.
Old 02-24-09, 09:09 AM   #3
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
If you are moving the same external soundcard from one PC to another you can transfer the file.
Old 02-24-09, 01:37 PM   #4
Silver Supporter
Alias: Will
Loc: Las Vegas
User: #33370
Since: Feb 2009
  thebuffman is offline
JohnM wrote: View Post
brit you never established if this card is external or internal.
i would agree with John when it comes to an external soundcard receiving power through the standardized usb bus. if the card was internal however then i would offer a different opinion since internal cards are subject to a disparate array of power supplies and power management on the mainboard which can have an impact on internal devices like hard disk and sound cards.
Old 02-27-09, 07:00 PM   #5
Alias: Mark
User: #33866
Since: Feb 2009
  BritInVA is offline
Its an external soundcard - but as has been mentioned its a pretty easy task to calibrate so no biggie.
file, soundcard
