REW ForumDiscuss iPhone SPL meter, instead of Radioshack? in the Equalization | Calibration forum; iPhone SPL meter, instead of Radioshack? Hey everyone, Have you tried using an iPhone with an SPL meter application to calibrate REW? Will it work? Cheers ... |
Views: 1526 - Replies: 6
| | #2 | ||||
| Re: iPhone SPL meter, instead of Radioshack? What do you mean, "Will it work?" Will it take SPL readings? Probably so. Will it work as the measuring mic for REW? Not unless it has a line output and a you have a calibration file for it... Regards, Wayne | ||||
| | #4 | ||||
| Re: iPhone SPL meter, instead of Radioshack? Hey, Sorry I should have been more specific. I have a behringer measurement mic, so I'm wondering what the easiest/cheapest way is to get the SPL measurements. I'd rather not go out and buy a dedicated SPL meter just to take one calibration measurement and then collect dust! Theoretically I could take the measurements in the room without calibrating the SPL level, no? Cheers Adam | ||||
| | #5 | |||||
| Re: iPhone SPL meter, instead of Radioshack? Quote:
brucek | |||||
| | #6 | ||||
| Re: iPhone SPL meter, instead of Radioshack? Okay, I get it now. No reason I can think of why it won't work. Even if it's accurate, but it shouldn't be a big deal. Just run the Set Levels routine as normal, and set it to 75 dB as usual. Be sure and run Check Levels before taking the measurement. If it shows too low, or clipping, just re-run the Set Levels routine and re-adjust for 73 dB, 77 dB or whatever.[Edit - it looks like brucek beat me to the "Reply" button. ]Regards, Wayne | ||||
