| REW Forum Diy Sub REW GraphDiscuss Diy Sub REW Graph in the Equalization | Calibration forum; Diy Sub REW Graph hi guys i was just wondering if i would benifit much from buying a BFD here is my in room ... |
Views: 727 - Replies: 6
| | #2 | ||||
| Re: Diy Sub REW Graph It's a bit difficult to interpret because we don't know the crossover you have chosen to use with REW. Is it 90Hz and is this your desired target? Can you re-post the graph with a vertical axis of 45dB to 105dB and since it drops off so rapidly at 20hz you may as well make your horizontal axis from 20Hz to 200Hz..... brucek | ||||
| | #4 | ||||
| Re: Diy Sub REW Graph It is quite a good response, but you could help it a lot with a BFD. If you raised the wholesale level of your sub such that the entire graphed response shifted up about 6dB, then you could cut approximately as I've shown below and have a better response. It's that area between 70-100Hz that would benefit the most.. There's a lot of signal in that area. ![]() brucek | ||||
| | #6 | ||||
| Re: Diy Sub REW Graph hi Will this http://www.andertons.co.uk/acatalog/...FBQ3102%2ehtml do the same job as the DSP1124P cause no one in the UK seems to have the DSP1124P in stock thanks | ||||
| | #7 | ||||
| Re: Diy Sub REW Graph That isn't suitable, if you can't find the 1124P go for the FBQ2496 http://www.dolphinmusic.co.uk/page/s...roduct_id/6360 | ||||
