REW Forum
Phase Plot
Discuss Phase Plot in the Equalization | Calibration forum; Phase Plot Hi, It must be me, but I can't find a setting to show a phase plot. If it's not me. ...
Views: 387 - Replies: 9
Old 03-03-09, 05:48 PM   #1
New Member
Alias: Iain
Loc: Europe
User: #34359
Since: Feb 2009
  Iain Apple is offline
Phase Plot
Hi,
If it's not me. Will this be available in a future version?
Thanks.
Iain.
Old 03-03-09, 07:42 PM   #2
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
Re: Phase Plot
It's not you and yes, the next release has phase and group delay plots.
Old 03-04-09, 01:45 PM   #3
New Member
Alias: Iain
Loc: Europe
User: #34359
Since: Feb 2009
Re: Phase Plot
Hi,
Thanks for your reply. But also thank you very much for the software. It is very impressive. Since it looks like you are going to add more features. I would like to make a few requests, if possible.
Coherence view and variable blanking (4 steps?)
Setup presets (maybe 6)
Addition of measurements, eg stitching of LF port to main etc. like MLSSA.
Defined averaging. ie vector/RMS.
Iain.
ps AES UK section meeting on the 10th March looks interesting.
Old 03-04-09, 06:02 PM   #4
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
Re: Phase Plot
REW only makes one calculation of the response, when multiple sweeps it pre-averages synchronously in the time domain before FFT so coherence would be 1. Frequency domain averaging is on the list to be looked at though, and I'll take note of the other items. What settings would you like captured in the presets?
Old 03-05-09, 02:44 PM   #5
New Member
Alias: Iain
Loc: Europe
User: #34359
Since: Feb 2009
Re: Phase Plot
John,
"REW only makes one calculation of the response, when multiple sweeps it pre-averages synchronously in the time domain before FFT so coherence would be 1."
Ok, but in "RTA" mode, I would have thought it would be helpful. Of course it's better to do an impulse and go from there.
"What settings would you like captured in the presets?"
Soundcard/Interface settings
Levels.
Time Offset
General Measurement/Generator settings
Mic Cal file
Iain.
Old 03-05-09, 10:56 PM   #6
Alias: Mike Bentz
DrWho's Avatar
Loc: Chicago
User: #2782
Since: Sep 2006
  DrWho is offline
Re: Phase Plot
I just wanted to echo a big thanks for the software too...I have found it extremely helpful in all sorts of applications.
One minor request....when using the loopback feature, would it be possible for the ETC and impulse to show absolute time?
-Mike Bentz
~It's all about compromise~
"It's territorial with the soundboard. So you're mixing and some dude comes by spewing opinions and trying to turn knobs. It's akin to going up to an artist and painting over his unfinished masterpiece. You just want to shove your paint brush up his nose and throw the soundboard out the window!"
Old 03-07-09, 12:31 AM   #7
Alias: Jim
Loc: Wetumpka
User: #630
  JimP is offline
Re: Phase Plot
John,
Will the phase plot provide for equalizer induced phase shift?
Old 03-07-09, 08:32 AM   #8
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
Re: Phase Plot
JimP wrote: View Post
Depends what you mean. If the equaliser is in the measurement path its phase shift will be included in the measurement.
Old 03-07-09, 08:41 AM   #9
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
Re: Phase Plot
DrWho wrote: View Post
It is certainly possible, are you aiming to compare arrival times between different measurements, e.g. to check speaker or drive unit time alignments?
A feature I have already included is an option to eliminate measurement delays through a process of cross correlation of the captured impulse with its minimum phase counterpart, that has the effect of finding the zero time of the system itself and eliminates all the time delays, whether in the soundcard path or the system itself.
Old 03-07-09, 07:28 PM   #10
Alias: Mike Bentz
DrWho's Avatar
Loc: Chicago
User: #2782
Since: Sep 2006
  DrWho is offline
Re: Phase Plot
JohnM wrote: View Post
Yep
It would also aid in multi-speaker systems...like a church or live venue with delay stacks, etc...
-Mike Bentz
phase, plot
