REW Forum
How to set the initial 75dB level for REW?
Discuss How to set the initial 75dB level for REW? in the Equalization | Calibration forum; How to set the initial 75dB level for REW? How do we set the initial recommended 75dB level of the AVR when using the REW?I understand that we should ...
Views: 393 - Replies: 2
Old 03-06-09, 10:45 PM   #1
Alias: rentangz
Loc: Philippines
User: #15930
Since: Jan 2008
  rentangz is offline
How do we set the initial recommended 75dB level of the AVR when using the REW?I understand that we should have the SPL meter RS or CM-140 to measure the 75dB but is this on a certain frequency initially say at 4khz just like the Rives Audio manual test CD recommended?or the REW gives a initial sweep of the frequency band selected and adjust the AVR volume to get the 75dB level?Using the sweep signal will not give a steady dB output level and the SPL will read varying signal level right?or is it using the pink noise to set the 75dB level?
Old 03-06-09, 11:16 PM   #2
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Re: How to set the initial 75dB level for REW?
75db is achieved by sending pink noise to each channel one at a time using an SPL meter at the listening position.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 03-07-09, 07:25 AM   #3
Alias: brucek
User: #6
  brucek is offline
Yes, band limited pink noise dependant on the test signal (full or sub) that is selected in REW.
Be sure to read and become familiar with the REW HELP files.
75db, initial, level, rew?
