REW Forum
Advice on measurement
Discuss Advice on measurement in the Equalization | Calibration forum; Advice on measurement Have applied eq to sub only and have now added my mains can someone give me any advice on how ...
Views: 262 - Replies: 2
Old 03-07-09, 01:56 PM   #1
Alias: James
Loc: scotland
User: #4512
Since: Nov 2006
  James Morrison is offline
graph looks and any tips on how to improve it. Thanks
Old 03-07-09, 02:42 PM   #2
Alias: brucek
User: #6
  brucek is online now
Re: Advice on measurement
Not bad at all.
Around 80Hz and 100Hz there are dips and peaks. I wonder if you have adjusted the phase control of your subwoofer (or distance of sub in receiver) to try and smooth that out a bit?
In the future try and post your graphs with the standard used here of vertical = 45dB-105dB and horizontal of 15hz-200Hz.
Old 03-07-09, 03:49 PM   #3
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
James Morrison wrote: View Post
In addition to the graph scaling, it would be helpful to see a sub only graph as well as subs and mains.
advice, measurement
