| REW Forum Can I set the measurement level to say 85dB for RT60 due to poor S/NDiscuss Can I set the measurement level to say 85dB for RT60 due to poor S/N in the Equalization | Calibration forum; Can I set the measurement level to say 85dB for RT60 due to poor S/N Hi
I´ve already asked several questions and I appreciate your prompt answer to all of them.
I will measure RT60 ... |
Views: 268 - Replies: 3
| Can I set the measurement level to say 85dB for RT60 due to poor S/N Hi I´ve already asked several questions and I appreciate your prompt answer to all of them. I will measure RT60 in a large classroom but I´m afraid the background noise might not be as low as I would like it to be. It might be around 50dB or a bit more. If I play my measurement signal at say 85dB (and calibrate the system to that output level) I will increase my SN Ratio by 10dB. Will that be a reasonable approach to tackle high background noise levels? Will it have an effect on the measurements? Also thinking of doing 2 to 3 sweeps per measurement to cancel out the background noise when these are averaged. Thanks | ||||
| | #3 | ||||
| Re: Can I set the measurement level to say 85dB for RT60 due to poor S/N Dont really know if they are averaged. But I read a few sweeps per measurment increased the SNR because the measurement of the room is the same while the background noise changes. | ||||
| | #4 | ||||||
| Re: Can I set the measurement level to say 85dB for RT60 due to poor S/N Quote:
brucek | ||||||
