Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Equalization | Calibration > REW Forum
REW Forum
  Discuss Any Ideas? in the Equalization | Calibration forum; Any Ideas? I just finished my first build and completed some initial adjustments. I've studied this forum and tried to apply all ...
Views: 420 - Replies: 20
Old 03-23-09, 07:10 PM   #1
Bronze Supporter
Alias: George
Loc: Lafayette, LA
User: #32511
Since: Jan 2009
  joorge is offline
Any Ideas?
I just finished my first build and completed some initial adjustments. I've studied this forum and tried to apply all the stuff I've learned here.
I set the gain on all of the speakers with a meter. I also did some testing with the MCAAC EQ, but it didn't help any and was off for all the charts. Cross over is 80 Hz and all speakers are set as Small.
I'm using the Shack's test tones with an RS meter and manually entering the data in REW with a correction file for the meter. REW helped me get 2 filters that were entered in my 1124. I'm attempting a house curve with the results in the following chart.
Name:  sub only filter 1.jpg
Next I tried all speakers with only a change in the phase setting on the plate amp. Here's what I got. I included the sub only chart for reference.
Name:  phase change.jpg
Then I took the best phase setting and ran a test out to 1kHz. Here it is:
That big hump looks ugly. I haven't had time to see how it sounds, yet. I tried to knock it down by using a custom EQ setting in the receiver. I set the filter at -6 dB @ 400Hz for all speakers. It didn't do much. I wonder if this is a room effect that can't be cured?
Any comments or advice is welcomed.
Old 03-24-09, 07:29 AM   #2
Shack Moderator
Alias: Anthony
Anthony's Avatar
Loc: Virginia
User: #2921
Since: Oct 2006
  Anthony is offline
Re: Any Ideas?
At 360 Hz, it's not entirely into the main speakers, but it's pretty close. You're two full octaves away from the crossover point, so at a minimum you're looking at being -27dB from the subwoofer at that point.
So that is most likely a main speaker/room interaction. Given where it is, it could be positional. Try moving the speakers out another 6" or 1' and remeasure. My first thought was baffle-step. Most speakers have a compensation circuit in them to accomodate low frequency rolloff of the speakers at wavelengths less than the baffle width. They are tuned for a particualr distance from the wall. Too close to the wall and you get more bass out of the speaker, too far out and you get too little. Sadly, unless the manuf. tells you exactly what they tuned it for, you are just sorta guessing. Most know how their speakers will be in-room, though, so 6" to 2' from the back wall is usually a good place to start.
It could also be a resonance, in which case moving it may help.
Next, I would try room treatments meant to absorb broadband around that frequency and that would definitely help.
Broadband EQ will not fix this if it is a resonance. You need narrow, targeted filters (like in the 1124) to spike those down.
Good luck.
Old 03-24-09, 11:16 AM   #3
Bronze Supporter
Alias: George
Loc: Lafayette, LA
User: #32511
Since: Jan 2009
  joorge is offline
Re: Any Ideas?
Thanks Anthony. I guess you are correct. I went back and looked at old charts that I made when learning to use REW. The hump is in all of them regardless of xover, phase or receiver EQ settings. I'll move the speakers around and see what happens.
Old 03-24-09, 11:57 AM   #4
Alias: brucek
User: #6
  brucek is offline
Re: Any Ideas?
Why aren't you using REW to take the measurements? They're much more accurate, and it takes only a second compared to the time it takes to do the manual method.
Old 03-24-09, 01:40 PM   #5
Bronze Supporter
Alias: George
Loc: Lafayette, LA
User: #32511
Since: Jan 2009
  joorge is offline
Re: Any Ideas?
Because I don't have all the necessary equipment. I don't expect to be doing this again for awhile, so I'll do it the hard way.
I'm happy I can get this far with a $25 used meter. The resources and expertise provided at the shack are rather extraordinary when ya stop and think about it.
Old 03-24-09, 05:49 PM   #6
Bronze Supporter
Alias: George
Loc: Lafayette, LA
User: #32511
Since: Jan 2009
  joorge is offline
Re: Any Ideas?
Moving the speakers a much as possible was worth less than -1 dB in the peak area. I plugged the rear ports and that had no effect.
I tried it without the center speaker and tamed the big peak, but got a smaller one around 153 Hz. Here's a chart with and without the center speaker:
Name:  no center.jpg
I'm out of time for now. I wonder if changing the phase or distance on the center speaker will do anything?
Old 03-25-09, 07:10 AM   #7
Alias: brucek
User: #6
  brucek is offline
Re: Any Ideas?
Why is there a center speaker being played at all?
Measurements should only be taken with mains and a sub, both when using REW and when using the manual tones method. They are both mono signals, so any processing with a multi-channel processor soundfield will not be valid.
Old 03-25-09, 12:17 PM   #8
Bronze Supporter
Alias: George
Loc: Lafayette, LA
User: #32511
Since: Jan 2009
  joorge is offline
Re: Any Ideas?
Thanks Bruce. You really have me confused. I have read everything I could find and have never seen anything about not using the center. Not doubting you for a minute, I'm just amazed that I didn't see that somewhere.
More confusion. How is it mono to have 2 mains in the test? Seems like that is stereo. Am I supposed to set the receiver to mono?
Doesn't the chart represent the SPLs where the measurement was taken? Isn't it really almost 10 dB louder around 350 Hz when I listen to music with all the speakers working?
Why wouldn't you want to look at the response with the setup you actually listen to? I'm not disputing your statements, just listing the questions that immediately popped up.
Obviously I'm missing something here. My knowledge is so basic that it must be inadequate to even get started. I hope you will take the time to help me understand.
Old 03-25-09, 12:48 PM   #9
Shack Moderator
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Re: Any Ideas?
joorge wrote: View Post
No, you only have stereo when you have two distinct signals. If you send a single discrete signal to both speakers, you merely have mono in two speakers.
When you have the center channel running, that means you’ve engaged Dolby processing. With a mono non-digital signal like your test tones, the default processing is Dolby Pro-Logic. Pro-Logic is not a discrete process like Dolby Digital, which means some signal bleeds into the L/R speakers in addition to the center. This can affect your measurements, as the mic is picking up a signal from all three speakers.
If you want to check the center speaker together with the sub, your best bet would be to switch the receiver to stereo mode, move the balance control to one side, then connect the center channel speaker directly to that channel.
Old 03-25-09, 01:04 PM   #10
Bronze Supporter
Alias: George
Loc: Lafayette, LA
User: #32511
Since: Jan 2009
  joorge is offline
Re: Any Ideas?
Thank you, wayne. The bulb has a dim glow, now.
I am remeasuring everything. Do I turn the unnecessary speakers off with the receiver or can I just unplug them?
ideas?
Bookmark and Share
Dish Network
