REW ForumDiscuss Signal Chain Question in the Equalization | Calibration forum; Signal Chain Question OK, here is my setup. Onkyo TX-SR806 AVR w/Audyssey MultEQ (Dynamic EQ), Klipsch RF-82 (dual 8" woofer) towers - bi-amped ... |
Views: 428 - Replies: 14
| Signal Chain Question OK, here is my setup. Onkyo TX-SR806 AVR w/Audyssey MultEQ (Dynamic EQ), Klipsch RF-82 (dual 8" woofer) towers - bi-amped because I'm only runing 5.1, Klipsch (12"/350 Watt) RW-12d sub and matching Klipsch center & surrounds. I am now going to add a BFD. I am using REW w/RS SPL meter. Here are my questions (first two of many more, I'm sure): 1) Do I run Audyssey first and let it get as close as it can and then setup BFD? 2) Do I run REW through AVR to get the bass from L/R towers in the reading? Thanks Steve | ||||
| | #2 | ||||
| Re: Signal Chain Question 1) Yes, run Audyssey first. 2) Yes, run it through the AVR but in order to test only the sub you will need to disconnect your speaker wires to the mains. Home theater: Onkyo TXSR805, Samson Servo 300 amp Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #3 | |||||
| Re: Signal Chain Question Quote:
Regards, Wayne | |||||
| | #4 | ||||
| Re: Signal Chain Question Ok, I ran Audessey first, then I ran REW with sub only (main/towers turned all the way down), loaded filters to BFD, re-ran REW with mains on and I am now trying to adjust filters and add some gain to some weak freqs. to get a smoother graph. Does this sound like the proper order to go? Should I now re-run Audessey, now that I am closer to flat in the low end range? | ||||
| | #5 | |||||
brucek | |||||
| | #6 | ||||||
How many positions did you test when you ran Audessey You should do at least 5, the more the better all 8 is the bast way to get good results. Home theater: Onkyo TXSR805, Samson Servo 300 amp Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||||
| | #7 | |||||
| | #8 | ||||
| Re: Signal Chain Question Thanks, I was trying to address some nulls and playing with 90Hz while my x-over point is 80 Hz. But should I not have the mains on while EQing the sub? Don't I want the low end response as smooth as possible (with woofers in towers engaged)? | ||||
| | #10 | |||||
