| REW Forum Help using MOTU Ultralite with REWDiscuss Help using MOTU Ultralite with REW in the Equalization | Calibration forum; Help using MOTU Ultralite with REW Hey folks
I downloaded room eq wizard to measure my room response but the problem is my ultralite shows up ... |
Views: 290 - Replies: 1
| Help using MOTU Ultralite with REW Hey folks I downloaded room eq wizard to measure my room response but the problem is my ultralite shows up as not having a mixer in windows (pic attached) therefore some of the REW drop-down menus for "input" and "output" devices are hidden. Ive got on to motu, who say that this is normal! Google isnt helping me either ![]() Im using a behringer ecm8000 mic, the ultralite has phantom power so its ok there Has anyone got a workaround for using REW with this audio interface? Thanks ![]() | ||||
| | #2 | ||||
| Re: Help using MOTU Ultralite with REW You need WDM drivers for the card for REW (or other Java apps) to be able to access it. | ||||
