REW Forum
Digital in REW?
Discuss Digital in REW? in the Equalization | Calibration forum; Digital in REW? brucek - in this post you say that you cant use digital out w/ REW. I used that same sound ...
Views: 606 - Replies: 2
Old 09-18-06, 07:46 PM   #1
jeffbridges
Inactive
Alias:
User: #
Posts: n/a
Digital in REW?
brucek - in this post you say that you cant use digital out w/ REW. I used that same sound card (SB Live ext) and since I didnt know which "line-out" to use (cause there isnt one) I used an optical cable instead.. Everything seemd to work fine with the digital out.. What am I missing?
Old 09-18-06, 08:50 PM   #2
Alias: brucek
User: #6
  brucek is online now
Re: Digital in REW?
What am I missing?
You're missing the ability to create a soundcard calibration file to ensure its accuracy........
Old 09-18-06, 09:04 PM   #3
jeffbridges
Inactive
Alias:
User: #
Posts: n/a
Re: Digital in REW?
You are correct sir... Was wondering why that didnt work... :-) Ok, back to Rat Shack for soem adapters...! jeff
