REW measurement question - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss REW measurement question in the Subwoofer Equalization | Calibration forum; REW measurement question I have been equalizing my subs with REW over the last couple of days. One thing I am unclear on ...
Old 09-18-06, 08:15 PM   #1 (Link)
Alias: Hakka
Loc: australia
User: #2510
Since: Sep 2006
Hakka is offline
I have been equalizing my subs with REW over the last couple of days. One thing I am unclear on and have been unable to find in the help file is how to go about re-testing the sub after filters have been applied.
I started by testing the un eq'd sub, I then applied the auto filters, and tweaked them manually while watching the corrected response graph. I then ran the sweep again, my sub response was a lot better, but the corrected graph is now all over the place, REW has applied the filters to a signal that already has the filters, if that makes any sense. I tried disabling all the filters in REW boefore running the sweep again but I get the same result.
What am I missing here??
Thanks.
Old 09-18-06, 09:02 PM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: REW measurement question
Uncheck the filters in REW when you want to do a new mesurement after you've entered filters into the BFD.
Old 09-19-06, 01:48 AM   #3 (Link)
Alias: Hakka
Loc: australia
User: #2510
Since: Sep 2006
Hakka is offline
Hmm...tried that, as soon as I reactivate a filter to tweak it the corrected graph goes out of whack.
Lets say I am using 1 filter at 50hz with a 10db cut, and have a freq response that is flat once this filter has been applied. I uncheck that filter and run the sweep, the measured and corrected graphs are identical, until I enable that filter to tweak it, which then moves the corrected graph down by 10db at 50hz relative to the measured graph.
Thanks.
Old 09-19-06, 06:56 AM   #4 (Link)
Alias: brucek
User: #6
brucek is offline
Well sure, because the signal you just measured with REW is a new equalized response after entering the filters that REW recommended. If you enable the same filters now in REW it will be like filtering twice.
If you want to manually add a new filter in REW to modify the equalized result you can.
Or you can slightly tweak the existing filters in the BFD and use REW to quickly measure the results.
Old 09-19-06, 05:26 PM   #5 (Link)
Alias: Hakka
Loc: australia
User: #2510
Since: Sep 2006
Hakka is offline
brucek wrote: View Post
Thats what I've been doing, I thought I might have been doing it wrong but I guess not. Thanks for your help Bruce.
Similar Threads
BFD and REW question about hook up and calibration apilon REW Forum 8 08-08-06 11:55 AM
Noob REW question... Vader REW Forum 2 07-11-06 09:14 AM
Odd REW question gacole2000 REW Forum 3 06-13-06 06:45 AM
REW, newrsdigital.cal, and c-weighting question Dent REW Forum 6 05-28-06 12:50 AM
"Highest level in the measurement is -49 dBFS" need help with REW union1411 REW Forum 5 05-12-06 04:55 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
