REW Forum
Exporting IR as pcm file?
Discuss Exporting IR as pcm file? in the Equalization | Calibration forum; Exporting IR as pcm file? Hey Just a quick question. Is it anyway possible to export the Impulse response from Room EQ wizard to a ...
Views: 258 - Replies: 2
Old 04-19-09, 01:09 PM   #1
Alias: Theealge
User: #20826
Since: May 2008
  Theeagle is offline
Hey
Just a quick question. Is it anyway possible to export the Impulse response from Room EQ wizard to a PCM file? I know it's possible to export the IR file in the .wav format and convert it using another program. It would be nice though if it was anyway possible to skip this procedure and export the IR directly as a .pcm file.
If this isn't posible. Does anyone know a quick an easy way to convert the .wav file to .pcm?
Thanks a lot
Old 04-21-09, 01:52 AM   #2
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is online now
Re: Exporting IR as pcm file?
REW doesn't offer .pcm export, mainly because the format is of limited use - typically 16-bit sample data and the format does not allow the data sample rate to be specified as it consists of just the raw sample values.
Old 04-21-09, 07:35 AM   #3
Alias: Theealge
User: #20826
Since: May 2008
  Theeagle is offline
Thanks for your reply!
I just wanted to use the IR file with DRC and hoped that it was possible to skip the converting, but that doesn't seemes like an option.
exporting, file?
