REW Forum
Going back to old laptop and SB USB Ext Card
Discuss Going back to old laptop and SB USB Ext Card in the Equalization | Calibration forum; Going back to old laptop and SB USB Ext Card Gave up on trying to get my new laptop to play nicely with REW. Going back to my old Dell ...
Views: 324 - Replies: 1
Old 04-19-09, 02:57 PM   #1
pbc
Alias: pbc
User: #11272
Since: Sep 2007
  pbc is offline
Gave up on trying to get my new laptop to play nicely with REW. Going back to my old Dell and SB USB 24 bit live card.
I can't remember how to hook up the Galaxy CM-140 Meter to the card? Do I use a 3.5mm mono male to male cable from the meter into an RCA Adapor into the Right (red) stereo audio adaptor which is connected into the Line-In connection on the Sound card?
I always get confused when I read the Help file as to whether the Y cables need to be used or if using my two stereo audio adaptors is fine! Been a while since I used the SB External Card!
At least this time the sound card calibration went smooth!
Also, with the Galaxy CM-140, if I recall, I leave the C-Weighted box in the Mic/ Settings tab unchecked correct?
Thanks,
Steve
Old 04-19-09, 03:12 PM   #2
Alias: brucek
User: #6
  brucek is offline
Re: Going back to old laptop and SB USB Ext Card
If the line-in of your soundcard is a stereo left and right jack, then it needs to be broken out into its left and right channels so that you can plug the meter into the right channel.
Check the box. The calibration file will over-ride the C-Weight box over its extremes.
back, card, laptop
