REW Forum
Attempted to dampen the back wall
Discuss Attempted to dampen the back wall in the Equalization | Calibration forum; Attempted to dampen the back wall Did this do anything good.. ? This is 1/6 and 1/3 smoothing of the same measurements(not sure what gives you ...
Views: 336 - Replies: 5
Old 04-28-09, 12:45 PM   #1
Alias: hybris
User: #32745
Since: Jan 2009
  hybris is offline
This is 1/6 and 1/3 smoothing of the same measurements(not sure what gives you the best impression), the blue is before, and the purple is after. I've added foam based dampening material behind three large, irregulary placed paintings on the back wall. One is about 100x50cm horisontal, while the other two are 90x35cm vertical.
I'm about to start listening to some music and see if I can detect any difference (I assume I'm not going to immediately do so) - but thought I'd post the graph first. It seem to have damped parts of the peak at about 1khz+, and overall slightly smoothed the response?
Note that I'm using a radio shack so the actual respons above 3khz may not reflect the room, but rather the mic, but the measurements are still useful to show the differences before and after. The mic was on a tripod, and I made several measurements between any changes done in the room dampening (added dampening between the paintings one by one and did several measurements between each) to be sure that the changes registered was consistent and not just random.
Any comments welcome
1/6
1/3
Thorbjorn -
Signal paths below
Home: Inguz EQ, Squeezebox, Shek NOS Dac, Denon 3805, EC AW250, B&W 804s, XTZ 99W10.16
Work: Electri-Q EQ, USB Lydkort, Shanling PH100, AKG 601
Old 04-28-09, 12:56 PM   #2
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Re: Attempted to dampen the back wall
To see improvements in room dampening, you'll want to use unsmoothed graphs. Typically these will show severely ragged response called comb filtering, like the example below shows. If your treatments get you a measurable improvement, the comb filtering will be less severe.
Name:  full range graph.jpg
Old 04-28-09, 01:07 PM   #3
Alias: hybris
User: #32745
Since: Jan 2009
  hybris is offline
Red face Re: Attempted to dampen the back wall
Ah - well then it actually seemed to have helped a little bit? the spikes are smaller?
Before:
After:
Thorbjorn -
Signal paths below
Old 04-28-09, 03:06 PM   #4
Alias: Wayne
Loc: Katy, Texas
User: #8
hybris wrote: View Post
Ah - well then it actually seemed to have helped a little bit? the spikes are smaller? :nerd
Yup, sure looks like it...
Old 04-28-09, 03:36 PM   #5
Alias: brucek
User: #6
  brucek is offline
Use the Measured tab to do comparisons..........
Use Waterfall and ETC to see the differences.
Old 04-28-09, 03:46 PM   #6
Alias: hybris
User: #32745
Since: Jan 2009
  hybris is offline
A few zoomed graphs (blue before and green after)
Thorbjorn -
Signal paths below
attempted, back, dampen, wall
