| REW Forum Cannot calibrate creative x-fi soundcardDiscuss Cannot calibrate creative x-fi soundcard in the Equalization | Calibration forum; Cannot calibrate creative x-fi soundcard I just measured the card with and without the mic cal. and I am getting good repeating measures with and ... |
Views: 1211 - Replies: 46
| | #26 | |||||
| Re: Cannot calibrate creative x-fi soundcard Quote:
When you say you do a measure - tell me what you do. What buttons are you pushing. Your plots above look suspect. The soundcard cal file should drop at the extremes (as it does) , and the Measure should be flat. Below is a typical soundcard calibration file and a measure of a loopback cable. The cable results show a flat purple line. The soundcard cal file is dotted. Note the vertical scaling I used - 1db per division. ![]() brucek | |||||
| | #28 | ||||
| Re: Cannot calibrate creative x-fi soundcard Yep, looks good. Now you simply remove the loopback and use that calibrated channel for your mic/preamp and output to the receiver for your measurements. Use only the analog line-out to the receiver - and you can use a Y-splitter to feed the left and right channel. Be sure the receiver is in the stereo only mode with its crossover engaged. To measure the sub alone, disconnect the mains speakers. Be sure to run the Check Levels (using the sub calibrate signal) Then run Calibrate and set to 75dB. Then Measure from 0-200Hz for the sub. Be sure to use the sub cal signal. Post all sub plots with a standard Vertical graph axis of (45dB - 105dB) and the Horizontal graph axis of (15Hz - 200Hz) using the Graph Limits button in the top right corner of REW. brucek | ||||
| | #29 | ||||
| Re: Cannot calibrate creative x-fi soundcard Got the REW to actually work today, but no real measurements and a lot of noise in the system when it is hooke up. I guess I need to start over again? | ||||
| | #30 | |||||
brucek | |||||
| | #31 | ||||
| Re: Cannot calibrate creative x-fi soundcard When I hook an rca cable to the output of the soundcard, a massive hum comes from the drivers. I then went directly to the back of the amp and it was a massive noise. Any thoughts? Thanks, Robert | ||||
| | #32 | |||||
I will do that shortly. | |||||
| | #33 | |||||
If so, this is likely a ground loop, or a bad cable. Be sure to plug the computer into the same power bar as the receiver. brucek | |||||
| | #34 | ||||
| Re: Cannot calibrate creative x-fi soundcard And always switch off your amps before changing any connections... | ||||
| | #35 | |||||
I tried a host of different cables to no avail. I turned everything oof and then powered up the amp it was connected to. Noise that gets louder as it goes-extremely loud. I pulled the cords and shut it down. I am going to reload the soundcard and retry everything. Thanks for the help. I am going to give the reload a shot tonight. Thanks, Robert | |||||
| | #36 | ||||
| Re: Cannot calibrate creative x-fi soundcard That behaviour would be typical of a feedback loop caused by monitoring being active in the soundcard's mixer. | ||||
| | #37 | |||||
Thank you, Robert | |||||
| | #38 | |||||
brucek | |||||
| | #39 | |||||
| | #40 | |||||
| | #42 | |||||
Double click the speaker icon in your System Tray. (The System tray is in the lower right hand corner of your computer screen). This will popup the Windows Playback Mixer. The jpg below shows that Playback Mixer and also shows how to switch between the Playback and Record Mixer and how to select what items to display in each mixer by using the check box. Note how the line-in is muted in the Playback Mixer. ![]() Now select the Record Mixer and ensure the line-in is enabled as shown in the jpg below. ![]() brucek | |||||
| | #43 | |||||
My panel only has master volume, wave volume, midi and cd. The recordhas cd, micrphone, mono out, and wave out. Thanks, Robert | |||||
| | #44 | |||||
brucek | |||||
| | #45 | |||||
I did that and those options are not listed. these are the boxes available. volume wave midi cd micrphone pc beep On the record option, these are the options cd microphone wave out mix mono out Nothing like you have listed can be checked. That is alll that is included in the properties menu. I cannot find anything else. Thanks, Robert | |||||
| | #46 | ||||
| Re: Cannot calibrate creative x-fi soundcard OK, I guess we won't go down that road any further. Can I see a jpg of your soundcard application. Maybe I will see something that isn't correct that is causing all this noise. brucek | ||||
| | #47 | ||||
| Re: Cannot calibrate creative x-fi soundcard Dumb question Robert. Are you using a laptop? If so have you tried running it off of the battery alone? My own set-up has a noise problem whenever I use the laptop power supply, but I wouldn't say it was a massive hum. Mine is just nasty background hiss and buzz. I'm just throwing that out there. It's probably not what you have going. | ||||
