| REW Forum REW as an RTA?Discuss REW as an RTA? in the Equalization | Calibration forum; REW as an RTA? I'm a new REW user and am using it together with a BFD DSP1124 to EQ a couple of different ... |
Views: 758 - Replies: 5
| REW as an RTA? I'm a new REW user and am using it together with a BFD DSP1124 to EQ a couple of different environments. My question is this: is there a way to use REW as a real-time spectrum analyzer rather than use the frequency sweeps or steps? That way I could use the pink noise and tweak the BFD. Scott | ||||
| | #2 | |||||
| Re: REW as an RTA? Quote:
brucek | |||||
| | #3 | ||||
| Re: REW as an RTA? Scott, First, welcome to the Forum! As an experienced RTA user, I can assure you that REW is just as effective as a real time analyzer for tuning a system. Actually, I think it’s even more effective. I’ve found EQng with a RTA and pink noise much more difficult than the REW’s sweep tone. The problem with pink noise is that it’s much more random than the pure tones REW uses, especially in the bass region. It’s tough to hone in on readings or a filter when your response is jumping around all over the place. Not that a RTA doesn’t have its uses. It’s good for showing the response program material is generating. I have one connected line-level to my system, and if something sounds wrong, like the male voices are excessively boomy, I can look over at the RTA and sure ‘nough, there’ll be a big ’ hump at 80 Hz. That new TV show Justice, for instance – dreadful-sounding dialog! RTA shows the response is hollowed out though the upper mid range. Some mastering studio needs to change out their monitors! Regards, Wayne | ||||
| | #4 | ||||
| Re: REW as an RTA? Thanks for the replies. I'll continue to work work with REW. The thing that is throwing me off is that the graph I get from a sweep fluctuates so wildly. In my limited experience with RTA's the display is averaged and not so detailed as REW. I revisited the help file and re-read the caution about not using a mic input (which the only input on my laptop). I have turned off the mic pre boost for that input, but it's still more sensitive than a regular -10 dB input. It may do some funky things to the freq response as well. I may need to get an external line in for my laptop. Thanks again for the input. Scott | ||||
| | #5 | ||||
| Re: REW as an RTA? If you are looking at full range responses then it is best to use some trace smoothing, 1/3 octave for example. This will clean up the displayed response considerably. | ||||
| | #6 | |||||
Note that we have now begun moving vendors to the new pull down option at the top of the forum pages. You will find it between "Shack Shopping" and "Glossary". This will represent a great improvement in the vendor reference database, making it easier than ever to find what you are looking for. Contact me with any suggested entries, category recommendations, or additional information about the vendors that we have. If you are a vendor and want your company listed, there is an option to provide us with the information. | |||||
