REW Forum
Soundcard Calibration L/R Difference
Discuss Soundcard Calibration L/R Difference in the Equalization | Calibration forum; Soundcard Calibration L/R Difference Hi, I'm new to REW and am trying to calibrate my laptop soundcard, but the right channel is ~9db higher ...
Views: 266 - Replies: 1
Old 05-14-09, 07:10 AM   #1
New Member
Alias: kraskland
User: #28726
Since: Nov 2008
  kraskland is offline
Hi, I'm new to REW and am trying to calibrate my laptop soundcard, but the right channel is ~9db higher than the left. I've read the help files and searched the forum but can't figure out a reason for this or how to fix it. Am I missing something or does this mean my soundcard is at fault.
Any help is much appreciated.
Old 05-14-09, 07:29 AM   #2
Alias: brucek
User: #6
  brucek is offline
Re: Soundcard Calibration L/R Difference
Calibrating a soundcard involves only one channel. Why are you calibrating 2 channels?
Most laptops do not have a line-in port. A mic-in port is not usable with REW. Hopefully, you're using a laptop with a line-in or an external USB soundcard.
calibration, difference, soundcard
