REW Forum
Which came first... the seating or the sub?
Discuss Which came first... the seating or the sub? in the Equalization | Calibration forum; Which came first... the seating or the sub? Given that listener location and sub location interact with each other, how do I go about determining the best location ...
Views: 337 - Replies: 13
Old 05-31-09, 08:39 PM   #1
Bronze Supporter
Alias: elee532
User: #24627
Since: Aug 2008
  elee532 is offline
Given that listener location and sub location interact with each other, how do I go about determining the best location for my listening chair and the best location for my sub? Most of the guides I have seen for subwoofer setup assume that the listening location is already chosen.
Thanks.
Old 06-01-09, 01:08 AM   #2
Alias: Mike Bentz
DrWho's Avatar
Loc: Chicago
User: #2782
Since: Sep 2006
  DrWho is offline
Re: Which came first... the seating or the sub?
Place the subwoofer in the corner and then walk around the room to find a good listening position. Moving the subwoofer around is only going to shift where peaks occur....the nulls should be close to the same for a given listening position.
-Mike Bentz
~It's all about compromise~
"It's territorial with the soundboard. So you're mixing and some dude comes by spewing opinions and trying to turn knobs. It's akin to going up to an artist and painting over his unfinished masterpiece. You just want to shove your paint brush up his nose and throw the soundboard out the window!"
Old 06-01-09, 10:20 AM   #3
Alias: TC
Loc: Worcester Mass.
User: #9814
Since: Jun 2007
  tcarcio is offline
You could try putting the sub where your seat will be, also known as the sweet spot, Then crawl, yes crawl, around the room until you find the spot where the bass sounds best and then put the sub there. You can do that for the spots that you are thinking of putting the seats and then you will at least have starting positions for the sub no matter where you decide to sit.
Old 06-01-09, 02:28 PM   #4
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
tcarcio wrote: View Post
Yes, this is correct. This is the best way to find a proper placement for a sub in any room.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 06-01-09, 07:57 PM   #5
Bronze Supporter
Alias: elee532
User: #24627
Since: Aug 2008
  elee532 is offline
What if I don't yet have a seating location picked out? I gues my question was... how do I go about picking a seating location AND a sub location? Which comes first?
DrWho wrote: View Post
Does it matter which corner I use? Does sub placement matter in relation to where I have bass traps located?
Can you explain the second part of this statement to me? I think I understand what you are saying about peaks. I'm not clear what you mean in your statement about nulls. Sorry, I'm a total amateur at this sound physics stuff.
Thanks all for the replies thus far!
Old 06-01-09, 08:49 PM   #6
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
elee532 wrote: View Post
If it were me.....I start picking the seating location first (use the 38% rule as a starting point; that means place your seat 38% of the lenght of the room from the back wall or 62% from front wall; example: lenght is 20ft, this will mean your seat will be 7.60feet from back wall or 12.40 feet from front wall).
Then, use the crawling method suggested by TCarcio.
I don't think so, bass traps need to be placed everywhere two walls meet (specially front and back walls)
Have you downloaded REW????....is a great tool to compare the frequency response on every spot you choose to place the subwoofer
Old 06-01-09, 09:59 PM   #7
Bronze Supporter
Alias: elee532
User: #24627
Since: Aug 2008
  elee532 is offline
Thanks salvasol. I do have, and am starting to understand, REW. In fact, it's kind of what led me to start this thread. I was doing some testing this weekend with the REW spectrum feature. I put the sub 38% from the back of the room, and then started moving the SPL meter into the different locations I had in mind for the sub. I could see lots of change as a I moved, but there were certain nulls that never seemed to get any better. I then randomly moved the sub into a different seating location and one of the nulls disappeared.
Of course, there are many more combinations of sub and seating location thus leading me to wonder if there is a standard process when both of these two variables need to be calculated. Unfortunately, it seems there isn't :-)
BTW, if you have any interest in the specifics of my situation, I have a thread going on here. The first set of graphs is my seating at 38% from back wall.
Thanks for your help!
Old 06-01-09, 10:10 PM   #8
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
... I could see lots of change as a I moved, but there were certain nulls that never seemed to get any better. I then randomly moved the sub into a different seating location and one of the nulls disappeared.
That's true, some are room related
Remember that to get a good response you need to take advantage from room, placement, EQ'ing and accoustic treatment (basstraps and acoustic panels)...you'll get there little by little
Old 06-01-09, 10:26 PM   #9
Bronze Supporter
Alias: elee532
User: #24627
Since: Aug 2008
  elee532 is offline
...acoustical treatments are done (probably covered about 60% of room corners with superchunk traps). No EQ until I my Emotiva UMC-1 shows up. So, just wracking my brain (and driving my wife crazy) trying to find the right room placement for seats and sub right now. :-)
Old 06-01-09, 10:45 PM   #10
Alias: Mike Bentz
DrWho's Avatar
Loc: Chicago
User: #2782
Since: Sep 2006
  DrWho is offline
If your room is a perfect rectangle then it's quite easy to identify where to put the listening position and subwoofers for the optimum bass performance. The problem is that any room irregularities dramatically complicate the acoustical scenario to the point of being practically unsolveable. Temperature and humidity play a role too.
I would also argue that a room with parallel walls is not at all conducive to a good sounding system so we shouldn't build a room to have parallel walls for the sake of making the acoustics predictable.
I guess what I should have said about room modes is that moving the sub and listening position around doesn't change the frequency of the problem....and the problem is really one of resonance. If you're not in a null, then you're sitting in a spot that is ringing. The modes are a function of the room's geometry so moving the subwoofer doesn't really change the ringing behavior. Think of subwoofer position in terms of wavelength....if your wavelength is 30ft, then moving the sub even 5ft isn't a very big change in phase.
I personally feel the ideal scenario is to always put the subwoofer in the corner to take advantage of the boundary gain and ultimately lower the distortion of the system. The room modes would then need to be addressed with the acoustical construction of the room...easy to say, but almost always impractical.
-Mike Bentz
Old 06-02-09, 07:27 PM   #11
Bronze Supporter
Alias: elee532
User: #24627
Since: Aug 2008
  elee532 is offline
True 'dat!!
Old 11-03-09, 10:28 PM   #12
New Member
Alias: Ronnie
Loc: Missouri
User: #44293
Since: Nov 2009
  BowerR64 is offline
When you place the sub in the seating area then walk around the room how do you know how to place the sub?
My subs are rectangle and my port is located on a spacific side. So when i try this how will i know how to position it? Do i just rotate it and then test it as well?
I built these cabnets with a spacific position in mind, im starting to wish i built them differently now.
Also i have 2 subs, do i put them both next to each other or somthing?
To bad REW couldnt come up with a box size and speaker type for where i want the subs placed.
Old 11-04-09, 12:26 AM   #13
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
BowerR64 wrote: View Post
If you like to read .....try this (Subwoofers: Optimum Number and Locations) ; if you want to skip all yada, yada, yada ....go to page 28 and read the conclusion about the best placement
Old 11-04-09, 01:29 AM   #14
New Member
Alias: Ronnie
Loc: Missouri
User: #44293
Since: Nov 2009
  BowerR64 is offline
Thanks, i cant wait to try this stuff.
I was about to run some wiring to my seats and sit my sub in the seat and then see if i could find a better location.
One thing i never thought of was insted of one large speaker use 2 little ones. I have 2 big ones so i guess that makes them both even bigger!
first..., seating, sub?
