REW ForumFirst measurments, with and without eq, Velodyne IC 600 Discuss First measurments, with and without eq, Velodyne IC 600 in the Equalization | Calibration forum; First measurments, with and without eq, Velodyne IC 600 Black = before auto eq Rd = after auto eq Sub: Velodyne In Ceiling 12" subwoofer with auto eq. I ... |
Views: 447 - Replies: 4
| First measurments, with and without eq, Velodyne IC 600 Black = before auto eq Rd = after auto eq Sub: Velodyne In Ceiling 12" subwoofer with auto eq. I was surprised to see a half-way decent before graph...and also suprised to see little change after the 7-band auto eq. | ||||
| | #2 | |||||
| Re: First measurments, with and without eq, Velodyne IC 600 Quote:
![]() Regards, Wayne | |||||
| | #3 | |||||
If you used the more reasonable standard that we use here of 45dB-105dB, you'd be amazed how flat that response actually is. You're using about a 20dB spread rather than the accepted 60dB. You should also take your measurements at 75dBSPL. brucek | |||||
| | #5 | ||||
| Re: First measurments, with and without eq, Velodyne IC 600 BFD in waiting....just need one more cable to complete the connection and it will be next. I do prefer having the ability to manually adjust the filters rather than letting the amplifier/dsp do it for me. I wish the Velodyne SC-600 gave some indication of what it was doing. | ||||
