| REW Forum Getting setup to run REW....Discuss Getting setup to run REW.... in the Equalization | Calibration forum; Getting setup to run REW.... I've read the connections section and I do understand what's being connected to what and why but it doesn't match ... |
Views: 257 - Replies: 7
| Getting setup to run REW.... I've read the connections section and I do understand what's being connected to what and why but it doesn't match my particular setup so I'm a little confused. My setup for both music and HT is run off of a HTPC running Vista Media Center. I connect from the onboard sound (Asus P5E-VM HDMI mobo) to a HK AVR-235 with digital coax. Now I guess first thing would be how do I do the soundcard calibration? I'm assuming I would want to include any effects the HTPC and AV receiver's XO has on the signal so would I loop back the SUB_OUT on the AVR to the soundcard input on the HTPC or set the mains to "large" and use that so the soundcard will see the entire audio spectrum? Thanks for any help, Ryan | ||||
| | #2 | ||||
| Re: Getting setup to run REW.... What are you trying to accomplish? Are you attempting to create a convolver DSP audio plug-in for Windows? Have you visited the convolver thread. brucek | ||||
| | #3 | ||||
| Re: Getting setup to run REW.... I'm trying to setup my sub and see how well it transitions over to my mains, or at least just get a plot at this point. Never heard of convolver but I'll go check it out. | ||||
| | #4 | |||||
| Re: Getting setup to run REW.... Quote:
Use the PC soundcards analog line-out and line-in and create the soundcard calibration file and use those ports (once calibrated) to plug your meter into and feed the AVR. brucek | |||||
| | #5 | ||||
| Re: Getting setup to run REW.... Using the analog audio out from the PC adds: - a DAC in the HTPC - an analog stage in the HTPC - an analog stage in the AVR - a ADC in the AVR extra to the signal path that wouldn't normally be there. So I'm OK to assume that after the signal goes through all those extra steps it will emerge at the SUB-OUT of the AVR with the same frequency response as if it weren't there? or are the differences minimal enough that they can be ignored? | ||||
| | #6 | |||||
The differences in the AVR wouldn't even come close to the difference in moving the mic a few inches when measuring. Since you appear quite concerned about precision, I assume you're using a professionally calibrated microphone? brucek | |||||
| | #7 | |||||||
FWIW I'm using an ECM8000 and a MIC800, hardly professional I'm assuming considering what it costs. The mic isn't calibrated though I would like to as soon as I find a place locally to do it. I just got it a few days ago so I haven't really looked too far into it. Thanks for the help Bruce! Ryan | |||||||
| | #8 | |||||
brucek | |||||
