| REW Forum Radio Shack SPL meter broken?Discuss Radio Shack SPL meter broken? in the Equalization | Calibration forum; Radio Shack SPL meter broken? my radioshack spl meter (analog) has suddenly started acting weird. When nothing is connected to it it measures correctly, but ... |
Views: 426 - Replies: 4
| my radioshack spl meter (analog) has suddenly started acting weird. When nothing is connected to it it measures correctly, but when I attach the output to the mic on my laptop (I've tried two different laptops), the meter maxes out, seems like it's getting some kind of feed through the cable that makes the meter go bananas.. Anyone ever experienced this or has any idea what might I have happened? Thanks Thorbjorn - Signal paths below ![]() Home: Inguz EQ, Squeezebox, Shek NOS Dac, Denon 3805, EC AW250, B&W 804s, XTZ 99W10.16 Work: Electri-Q EQ, USB Lydkort, Shanling PH100, AKG 601 | ||||
| | #2 | |||||
| Re: Radio Shack SPL meter broken? Quote:
Most computer mic-in ports supply a small DC voltage to operate the cheap computer mics that are available. You usually require an external USB soundcard for REW when using a laptop. brucek | |||||
| | #3 | |||||
Thanks a bunch! ![]() Thorbjorn - Signal paths below ![]() Home: Inguz EQ, Squeezebox, Shek NOS Dac, Denon 3805, EC AW250, B&W 804s, XTZ 99W10.16 Work: Electri-Q EQ, USB Lydkort, Shanling PH100, AKG 601 | |||||
| | #5 | ||||
| Re: Radio Shack SPL meter broken? Not hybris but, After using my wife's desktop system to take REW measures, I was pleasantly surprised to find that the soundcard on my laptop can be configured as LineIn as well as mic. It's a Dell XPS with a SigmaTel High Definition Audio chip. When I plug a stereo mini plug into the mic input, Windows Vista prompts with a dialog asking what kind of device is attached, offering a choice of mic, line in, or rear speakers. (The laptop has three audio jacks, two headphone/speaker jacks that can double as the front L/R and center/sub speakers, and a mic jack that doubles as the rear L/R speakers.) The laptop soundcard is not quite as flat as the desktop system at the low end nor at the high end, but it using it for calibration I see similar results from both systems. | ||||
