| REW Forum REW not generating a measurement signalDiscuss REW not generating a measurement signal in the Equalization | Calibration forum; REW not generating a measurement signal Hmm. I've used REW with great success a few months ago. Today, though, my system was moved into a new ... |
Views: 247 - Replies: 6
| REW not generating a measurement signal Hmm. I've used REW with great success a few months ago. Today, though, my system was moved into a new room and I've been unable to repeat measurements. I'm able to play music but not generate a test signal from REW. No hardware or configuration has changed since the successful measurements but I have installed Media Monkey with ASIO drivers and done the usual Vista updates. I thought that it might be the ASIO drivers so I've dis-abled these in Media Monkey (and haven't seen them in the mix application that comes iwth my Lynx L22 card). All other applications seem to generate sounds. Any ideas? APS | ||||
| | #2 | |||||
| Re: REW not generating a measurement signal Quote:
brucek | |||||
| | #3 | ||||
| Re: REW not generating a measurement signal Check on the soundcard settings page that the correct card and output are selected and that the volume settings (if controlled) are correct. | ||||
| | #4 | ||||
| Re: REW not generating a measurement signal I have also used REW for many months without any issues at all. Today I installed and run TrueRTA and now all the measurement I get from REW are all over the place. Every measurement I take yields different results. So I did a system restore of my PC to get back to where I was before the TrueTRA and now I can take measurement and while the results look the same on the graph for each measurements I took, I cannot get the db to around 75. No matter where the volume level is on the AV processor and the volume control on the PC, it always read @104db. How can I bring the db down to 75? | ||||
| | #5 | ||||
| Re: REW not generating a measurement signal You are suppose to run the Calibrate routine after the Check Levels routine and set the internal REW SPL meter to the level at the listening position. brucek | ||||
| | #6 | ||||
| Re: REW not generating a measurement signal I did a check level and set the SPL @75 which is the reading I got from my Radio shack meter at my listening position. | ||||
| | #7 | |||||
You are suppose to run the Calibrate routine after the Check Levels routine and set the internal REW SPL meter to the level at the listening position. brucek | |||||
| Bookmarks |
| Tags |
| generating, measurement, signal |
| Thread Tools | |
