REW Forum
dbx RTA-M or Behringer ECM8000 for REW
Discuss dbx RTA-M or Behringer ECM8000 for REW in the Equalization | Calibration forum; dbx RTA-M or Behringer ECM8000 for REW This has probably been discussed before, but cannot find a definitive answer (sorry if it has been covered). Which of ...
Views: 378 - Replies: 4
Old 06-15-09, 01:02 PM   #1
Silver Supporter
Alias: Ray
cavchameleon's Avatar
Loc: Albuquerque, NM
User: #15210
Since: Jan 2008
  cavchameleon is offline
This has probably been discussed before, but cannot find a definitive answer (sorry if it has been covered). Which of the two mics are more accurate for REW (with the cal files that can be downloaded from HT Shack). I do realize that they are generic cal files an cannot guarantee reference readings.
Thanks
Ray
Ray
Happy Listening!!! Listen with an open mind and heart!!!
Old 06-15-09, 01:59 PM   #2
Alias: brucek
User: #6
  brucek is offline
Re: dbx RTA-M or Behringer ECM8000 for REW
ECM8000...
Old 06-15-09, 02:09 PM   #3
Silver Supporter
Alias: Ray
User: #15210
Since: Jan 2008
Brucek,
Thanks for the reply. Can you elaborate why? Curious since the ECM8000 can be had for half the price of the dbx. Does the ECM8000 have a more accurate capsule?
Ray
Ray
Old 06-15-09, 02:22 PM   #4
Alias: brucek
User: #6
  brucek is offline
Because the ECM8000 is the only mic we supply a calibration file for..... the DBX file you see floating around is somewhat crude - not done by a professional company using the techniques that created our ECM file.
Old 06-15-09, 02:38 PM   #5
Silver Supporter
Alias: Ray
User: #15210
Since: Jan 2008
brucek wrote: View Post
Thanks! That definitely clarifies it! I downloaded both cal files, so will delete the dbx file and try both the dbx and ECM8000 (with the cal file) with REW (just for fun's sake, curious how much of a difference there is between the two).
Ray
behringer, ecm8000, rta-m
