Tonal EQ calibration (there's more than subwoofers in your system!) - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss Tonal EQ calibration (there's more than subwoofers in your system!) in the Subwoofer Equalization | Calibration forum; Tonal EQ calibration (there's more than subwoofers in your system!) In the course of experimenting with the pro sound system I've been testing REW with (see pro sound posting), I ...
Old 10-03-06, 11:14 PM   #1 (Link)
New Member
Alias: Eric
Loc: Mountain View, CA
User: #2824
Since: Sep 2006
enovikoff is offline
In the course of experimenting with the pro sound system I've been testing REW with (see pro sound posting), I noticed something interesting. I have one of those "purist" systems with a Theta Digital controller that has every bell and whistle... but no tone controls. Who needs 'em, anyway? Right? Right? I found out this last weekend that was totally wrong for me.
First of all, some background. I have Aerial 10T speakers: finicky, but with sufficient effort to room acoustics, you get incredible sound. However, I tend to move my furniture around a lot, so the attention to room acoustics isn't practical for me. So last weekend, I put this pro live sound reinforcement system in my livingroom to play with it. It has some Mackie SRM450 powered full-range speakers on stands. These speakers aren't particularly accurate, nor are they particularly musical. Of course, they sounded worse than my Aerials (even if they are a lot louder!) I had difficulty distinguishing details in test CDs as well as getting the feeling I usually do that "I'm there." But then, I started using REW to do tonal EQ on the system. What I mean by tonal EQ is measuring the response of the room above 500Hz, and compensating for it to get a "flat" response (or in the case of some of my test CDs, using some tweaks on the EQs as tone controls to fix bad mixing in the studio.)
Voila'! The sound opened up and details became distinguishable, and overall the presentation was much more balanced, pleasant and listenable. Unfortunately, I won't be able to try this with my own setup, since the pro sound system is racked up and hardwired, not to mention using a $5000 DSP system. But it's definitely getting me interested in some sort of adjustable EQ, set up with manual filters from REW for now, with my normal setup.
Has anyone else experienced this? Have we dumped the graphic equalizers of yore in the quest for perfection, only to produce sterility and loss of musicality as a result?
I'll let you know what happens when I manage to EQ my normal system....
Best regards,
-eric
Old 10-03-06, 11:33 PM   #2 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Re: Tonal EQ calibration (there's more than subwoofers in your system!)
Sure – we all have $5000 digital EQs in our systems. Kidding aside, many receivers these days have digital room compensation that for the most part seems to be really effective. Not sure if it can make a silk purse out of a sow’s ear, like the BSS did to the Mackies, though...
Not a fair comparison, I’m afraid, comparing those tinker-toy 10-band EQs or yore with that DSP wonder. I was happy with the results I got with my AudioControl 1/3-octave EQ’s though.
I’ll be interested to see what the Soundweb can do for your Aerials...
Old 10-04-06, 04:55 AM   #3 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is online now
Remember the Cello Audio Palette? That had the audiophiles raving about how wonderfully a bit of well-implemented and carefully adjusted EQ could improve the sound, and as I recall it wasn't even parametric. http://www.celloseattle.com/ctdocs/p...iopalette.html
Old 10-04-06, 05:09 AM   #4 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is online now
Here's an interesting follow-up on that, Eric: http://www.avrev.com/news/0306/22.burwen.shtml & http://www.burwenaudio.com/BURWEN_BOBCAT.html
Not sure about the "digital music [...] possibly has ill effects on your health" bit, maybe it depends which band is playing
Similar Threads
My eclectic HT system technimac Home Theater Equipment 0 09-21-06 04:49 PM
My System chasw98 Home Theater Equipment 0 09-19-06 06:20 AM
Calibration Problem felubo REW Forum 6 09-08-06 11:09 AM
Soundcard Calibration? Ross Winn REW Forum 2 08-22-06 07:21 AM
Four Subwoofers Ayreonaut Home Audio Subwoofers 25 07-05-06 10:03 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
