| REW Forum BK Monolith with REW + BFDDiscuss BK Monolith with REW + BFD in the Equalization | Calibration forum; BK Monolith with REW + BFD Hi from Adam in the UK.
Firstly, great site and thanks to all the useful information on here. I wouldn't ... |
Views: 259 - Replies: 2
| BK Monolith with REW + BFD Hi from Adam in the UK. Firstly, great site and thanks to all the useful information on here. I wouldn't have got to where I am now without it. Could you please critique my graphs and setup, and help me get the most out of my system ![]() - EMU configured through REW. - Initial 75db config. - 1/3 smoothing on all plots. 1. Speakers only Speakers 3m apart on 6.5m wall. Sitting position 4m away on opposite wall. A bit far apart atm ![]() ![]() 2. Sub only - Monolith - 10 oclock gain, 9 oclock phase, sat on right edge of tv cabinet. - x2 REW automatic filters applied through BFD, and a few extra notch ones. - 10db house curve applied after 'by ear' comparison of 32hz vs 100hz. - Shelf filter at 366hz, -20 gain, 120/60 bandwidth: To bend sub curve to house curve line. ![]() 3. Sub + speakers together - 90hz x-over through yamaha E800. ![]() 4.) All the above - The 'green' speakers + sub together line had a massive dip at 93hz when they were ran together (don't know the theory, destructive inteference ???) so I kept the peak on the sub only graph at this point to remove the dip when both played together. - Other peaks/dips at 45 and 75 when speakers and sub ran together. ![]() Any ideas on the above and why it happens, gap in my knowledge. Overall it sounds great, and a house curve is amazing and just what the doctor ordered for bass impact during films. Any improvements to be made ? Will be getting a new processor this summer (probably the new Emotiva UMC1), so will have to go through all of this again ![]() | ||||
| | #2 | ||||||||
| Re: BK Monolith with REW + BFD Quote:
Your mains are acting fairly nasty. I would measure each main individually and see where the dips and peaks are derived from. If each main looks good by itself, it's an interaction. If a main by itself is bad, it's a room reflection. Quote:
You'll note how your high filter drops the response too quickly. I would correct the mains (if possible) with positioning, and then redo the sub without the high filter, then adjust sub phase with sub and mains together to smooth crossover and your response will be great. brucek | ||||||||
| | #3 | ||||||
Regards, Wayne | ||||||
